need help with codes explanation e350 v10
Old Nov 15, 2007 | 01:25 PM
szpieleusa's Avatar
szpieleusa
Got codes today and found them in the internet, but it means nothing to me maybe somebody can help me?
p1130 - lack of HO2S-11, Fuel Trim At Limit
p1150 - lack of HO2S-21 Switch fuel trim at limit???
Richard
Old Nov 15, 2007 | 01:29 PM
szpieleusa's Avatar
szpieleusa
And please explain to me what is difference between 3.55 non-limited slip axle
and 4.10 limited slip axle in diesel e-350? What is better and for what?
Old Nov 17, 2007 | 02:13 AM
Desert-Rat's Avatar
Desert-Rat
The difference is the size of the gears. 4.10 is a lower gear and would be better for towing very heavy loads especially in the hills or on surface streets.. 3.55 does well towing but is a higher gear set and will give you better mileage on the freeway.
Limited slip will give you better traction. the drive tire is allowed to slip to a certain extent before traction is transfered to the opposite tire for assistance.
non-limited slip means only one drive tire... don't get it stuck or you'll never get it out!
I tow about 3,500lb trailer and load up on camping gear and travel severe back roads and dirt trails and my Dana 60 limited slip w/3.73 gears and it does just fine.
in my opinion I would choose the 4.10 limited slip!
Old Nov 20, 2007 | 10:15 AM
Clubwagon's Avatar
Clubwagon
Fuel trim at limit indicates that the computer's ability to adjust the fuel mixture has maxed out. There should be a rich or lean code with these. If those are the only codes, clear them and see if they return.
A limited slip axle has a clutch that reduces the slip between the rear tires. So in slippery conditions both wheels have drive while a non-limted slip would only drive one wheel. So you would just spin the one rear wheel that has less traction. Unless you go offroad or drive in snow/ice, you don't need the limited slip axle.
Steve
'95 Clubwagon XLT
Old Nov 24, 2007 | 11:22 AM
szpieleusa's Avatar
szpieleusa
need help further
Thanks for Your answers and respect for You both! I'm writing private because i need help further and i have limited time to fix my clubwagon. About codes: yes, there are two other codes about too lean (fuel?) in "bank1" and "bank2" besides the ones iwrote earlier. What does it means?
Old Nov 26, 2007 | 09:34 AM
Clubwagon's Avatar
Clubwagon
Too lean bank one and two means that the oxygen sensors on both sides of the motor are reading lean. You can therefore assume that the engine is running lean enough that the PCM cannot adjust far enough to bring it into proper ratio.
Clearly you have a very lean condition that must be addressed. The first thing to check is fuel pressure. The regulator may be bad, or you may have a stopped up fuel filter or a fuel pump that is failing. Even a crimped fuel line could do it.
Good Luck,
Steve
'95 Clubwagon XLT
Old Nov 26, 2007 | 01:51 PM
Moore558's Avatar
Moore558
Also check for any vacuum leaks. That will cause lean codes in a hurry.
Old Nov 26, 2007 | 02:08 PM
Clubwagon's Avatar
Clubwagon
True. Also, I had a bunch of lean codes when the snorkle behind the MAF sensor split.
After you diagnose and repair the problem, check the catalytic converter. Depending on how long the problem has existed, your converter may have failed.
Steve
'95 Clubwagon XLT
Diver down
Jan 3, 2016 02:13 PM
gopher2
Jun 1, 2014 09:11 AM
ddwood55
1997 - 2003 F150
Jan 2, 2012 04:58 PM
winter123
1997 - 2003 F150
Sep 27, 2009 07:50 AM
PAFordFan
3.8 & 4.2L V6
Apr 18, 2007 08:16 AM
