In case you missed it - - -
Old Nov 15, 2007 | 12:15 PM
WillyB's Avatar
WillyB
This was posted in the member's only forum - Do you guys have any comments?
"I was thinking about turbo charging my Vette. I got to thinking about it and how in efficient even turbos are (compressor efficiencies of about 80% at best).
Since a turbo's function is to pressurize incoming air and force it into the upper motor, and turbos are driven by high pressure exhaust gas created from the combustion process, couldn't I just bypass the turbo altogether and route my headers back into the throttle bodies?
Since I have CFI, I could balance the DEI (direct exhaust injection as I just coined it) by feeding one header into each throttle body. Yes, the charge air wouldn’t be that cold, but it would be under a hell of a lot more pressure.
I attached a quick sketch below: "
Old Nov 15, 2007 | 01:26 PM
3Mike6's Avatar
3Mike6
Does he want the long or short version of of why it will not work?
I don't want to sound like an ***, but
There's no intake, exhaust pressure are generally less than 1-psi (= no boost).
All he's really drawn is a way to creat extreme backpressure and eliminate air intake.
I wonder if the OP realizes there are two parts to a turbo? i/e the exhaust spins one side, the other side (going into the intake) spins to create the boost?
Also, I think turbos are more efficient than he's posted...belt driven superchargers/etc, loose 20-25%, the only thing "wrong" about turbos is the initial lag until it gets spooeld up to start making boost.
Old Nov 15, 2007 | 05:46 PM
Jag Red 54's Avatar
Jag Red 54
Come on Clint, you got to be kidding. Where does he think the O2 is going to come from for the combustion? Jag
Old Nov 15, 2007 | 06:51 PM
WillyB's Avatar
WillyB
Bingo, you got it!!!!
10 members of the Chevy forum forgot that, and several members of the FTE supporter forum missed it too -
I think he posted it as a joke, but most people missed the punch line!
It was worth a good laugh!!!!
Things were too quite and slow in here.
Old Nov 15, 2007 | 07:08 PM
3Mike6's Avatar
3Mike6
Punchline?
Okay, spell it out for me.
Old Nov 15, 2007 | 07:42 PM
AnOldDog's Avatar
AnOldDog
Originally Posted by 3Mike6
Punchline?
This is an extremely efficient design. It will come close to acheiving an infinite MPG rating. It goes nowhere and thus uses no fuel. 0/0=DIV error.
Old Nov 15, 2007 | 09:10 PM
WillyB's Avatar
WillyB
Punchline?
We can not burn exhaust gas! It takes air (oxygen) to support combustion. I don't think the engine would start, but if it did it would only run for one turn.
Old Nov 15, 2007 | 09:19 PM
cmpd1781's Avatar
cmpd1781
I thought the first guy in the Chevy forum called this genius a stupid MF.......He didn't elaborate WHY....He just called him that name......
Old Nov 15, 2007 | 10:09 PM
olfordsnstone's Avatar
olfordsnstone
Great!!!
Now that I've modified my 460 with a sawzall, cutting torch and mig welder.
Thanks allot Clint. Sure coulda spoke up a little sooner.
Old Nov 16, 2007 | 10:52 AM
Keepin It Real's Avatar
Keepin It Real
It's like the snake swallowing it's tail.
Old Nov 16, 2007 | 11:44 AM
WillyB's Avatar
WillyB
Yea, would have been neat - sort of a perpetual motion machine!
Tim, why not add a fitting to the inlet and squirt some starting fluid in?
Old Nov 17, 2007 | 05:25 PM
olfordsnstone
Yea Clint. I was thinking of plumbing in a copper line into the exhaust re-breather from an oxygen bottle located in the bed of the truck. A little ether induction might help the combustion process a little too, I suppose. Might be kind of hard keeping the plugs from blowing out though.
