Hard one to start
Old May 8, 2002 | 12:33 PM
fat_trucker's Avatar
fat_trucker
Hard one to start
I've got a 73 240 I-6 with about 350k miles on it, and believe it or not, it runs like its brand new, and IT'S ALL ORIGINAL! The only problem is, that it is a bear to start when its cold. I mean to the point of puoring gas down the carb to start it. Once it warms up its great, any reasons it may be doing that? Thanks
Old May 8, 2002 | 12:53 PM
mantta's Avatar
mantta
Hard one to start
Did you check to see if the choke was closing on it? Or maybe, the check valves in the fuel pump are getting tired and the fuel is bleeding back to the tank when it is sitting.
Old May 8, 2002 | 01:32 PM
fat_trucker
Hard one to start
I run the choke manually and it does open and close fine, and I'll check the fuel valve to see if it does leak. Thanks a bunch.
Old May 8, 2002 | 02:55 PM
stractor's Avatar
stractor
Hard one to start
