95 ford aod shift problem
Old Nov 14, 2007 | 09:02 PM
Wild Karrde's Avatar
Wild Karrde
God I love Bronco's. I hope to someday own one.
Old Nov 14, 2007 | 09:40 PM
385seriesHemi's Avatar
385seriesHemi
Yeah easy checks for automatics not shifting well generally is bad fluid, or low fluid. And if its a Electronic controlled a solenoid can be a culprit. Sometimes the vaccum modulator can be a culprit also from NON electronic controlled. As for the EAOD & AOD that cable not being in adjustment will do some goofy stuff. What I was tought was every 30,000 miles do a pan drop or flush to the transmission or what company specifies if its a special application.
