Sensor vanished into thin air
Old Nov 14, 2007 | 05:07 PM
tolmite's Avatar
tolmite
Ok, I was replacing my EBP tube and was finishing up. I went to screw the sensor back in and my butter fingers dropped it. Now it seems to have vanished into thin air. I figured while I take a break from looking for it (close to 2 hours now) maybe someone might have a suggestion of where it might have gotten hung up at that I haven't searched yet.
Old Nov 14, 2007 | 05:13 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
in the radiator shroud. grab a flashlight and look from the bottom, you can pull the plastic cover on the top (the cover between grill and radiator).to make it easyer.i bet you its there.
good luck
Old Nov 14, 2007 | 05:16 PM
IDPisan's Avatar
IDPisan
That is where mine went, I had to macgyver some tie wire to get it out.
Old Nov 14, 2007 | 05:26 PM
ron's power stroke's Avatar
ron's power stroke
i still have a 9/16 wrench and a 5/8 socket hidding in my truck..i looked for over 2 hours before i gave up..i still look for them when ever i open the hood..this was 6 minths ago...good luck on finding the sensor..
Old Nov 14, 2007 | 05:53 PM
jeepster1272's Avatar
jeepster1272
Check behind the water pump pulley, that's where mine went.
Old Nov 14, 2007 | 06:43 PM
tolmite's Avatar
tolmite
Well, took off the radiator shroud, not there, not behind the pulley. I'm giving up for the night and will try again tomorrow. Will the truck run without that sensor (in case I can't find a ride to get a new one)?
Old Nov 14, 2007 | 07:34 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
It's a long shot but if you're in Texas and close to me I have an extra sensor that you can have.
Old Nov 14, 2007 | 08:03 PM
tolmite's Avatar
tolmite
Thank you for the offer but I'm up in Michigan.
