correct pinion angle
Old Nov 14, 2007 | 10:05 AM
livewire21's Avatar
livewire21
hey all, i did a search and still did,nt find what i think i need to know.lol i lowerd the rear of my 60 f100 couple days ago, by moving spring hangers up on the frame. can anybody tell me what the driveshaft and pinion angle should be to work together. the rear axle was not removed from springs, i didnt flip anything just moved hangers higher on frame.
Old Nov 14, 2007 | 10:25 AM
53OlderThanMe's Avatar
53OlderThanMe
I think I remember reading 2 degrees foward tilt on the rear axle was stock. It may be different on various trucks/configurations.
Old Nov 14, 2007 | 10:35 AM
Randy Jack's Avatar
Randy Jack
This may help: http://www.clubfte.com/users/jniolon...nephasing.html
Old Nov 14, 2007 | 10:58 AM
RUSTY50F1's Avatar
RUSTY50F1
Thanks RJ that's what I've been looking for to.
Old Nov 14, 2007 | 01:56 PM
53OlderThanMe
Originally Posted by Randy Jack
Adding that to my favorites
Old Nov 19, 2007 | 04:51 PM
YEEHAABILL's Avatar
YEEHAABILL
Pinion angle
Y-Guys
A little food for thought. The angles from the trans end and the diff
end need to be the same or as close to it as possible. Imagine a line straight
out of the Yoke(either end) and a line in the middle of the driveshaft, the angle
created at their intersection,normally 4/6degrees is what you're shooting for.
Under acceleration the pinion tries to climb the ring gear, so you may have some
vibration then. You can alter the angle with shims if needed.
Hope this helps.....Bill
