Tranny fluid leak
Old Nov 14, 2007 | 09:01 AM
Bertha1's Avatar
Bertha1
Question Tranny fluid leak
Howdy everyone. I'm looking for some guidance on leaking transmission fluid. Is there an easy way to trace the leak? I am adding about a quart of fluid every 10 days or so. I was thinking a bad gasket on the pan could be a good place to start but was curious if anyone had found a leak elsewhere.
Old Nov 14, 2007 | 09:05 AM
tomtoc's Avatar
tomtoc
what kind of tranny? spots in the driveway or not?
Old Nov 14, 2007 | 09:17 AM
Skandocious's Avatar
Skandocious
You're the one that has to find the leak, it could be in a number of places. I had a bad seal on my last gasket which seeped A LITTLE BIT but not even enough to drip. If you have it overfilled and/or are overheating it, it could be dripping out of the breather. Otherwise, it's probably the front seal on the transmission.
