Dana 80 help
Old Nov 13, 2007 | 05:26 PM
Cwboy's Avatar
Cwboy
Dana 80 help
Hi there all, well i am sure some where out there on this site the info is to be found i have spent over a hour looking for it so i though maybe some one out there would know where to look. I have a 2000 F450 superduty 2x4. I know it has a Dana 80 in it but not sure the gear ratio, the axel code is D787e, I need to do something with the ratio as right now to do 110 Km/h i am running over 2600 rpm.
Thanks for any help
Old Nov 13, 2007 | 06:32 PM
tjc transport's Avatar
tjc transport
i ain't rite
look on the driver side "B" pillar. there will be a sticker with the truck codes on it. look for the axle code, and post it. then we can tell you what you have.
G3 — 4.30 limited slip, F-450 Chassis Cab
73 — 4.30 non-limited slip, F-450 Chassis Cab
78 — 4.88 non-limited slip, F-450 Chassis Cab
G8 — 4.88 limited slip, F-450 Chassis Cab
75 — 5.38 non-limited slip, F-450 Chassis Cab
G5 — 5.38 limited slip, F-450 Chassis Cab
GW — 4.10 limited slip, F-450 Chassis Cab
Old Nov 13, 2007 | 08:14 PM
projectnitemare's Avatar
projectnitemare
Or if you feel inclined jack up a wheel and spin it while you count the number of driveshaft revolutions for one turn of the wheel.
Matt
