Transmission ??
Old Nov 12, 2007 | 08:22 PM
Modified 99's Avatar
Modified 99
Red face Transmission ??
How can I tell if I have the 4R100 or 4R70W transmission?
What is the total fluid capacity of each?
Old Nov 12, 2007 | 08:54 PM
FTE Herman's Avatar
FTE Herman
Square pan, 4x4, drain plug, 5.4l.
Old Nov 13, 2007 | 09:17 AM
buzzard's Avatar
buzzard
The 100 has a massive boxy look while the 70 has a more traditional bell shaped look. Additionally, most 100's have drainplugs. The 100 holds around 17 quarts including torque converter.
Old Nov 13, 2007 | 09:55 AM
Nelson acc's Avatar
Nelson acc
FTE Sponsor
www.accperformance.com
888-267-7464
Old Nov 14, 2007 | 06:03 AM
Modified 99
Since my transmission does NOT have a drain plug it must be the 4R70W. I'm going to change the fluid today including the filter, TC and cooler.
Old Nov 14, 2007 | 08:08 AM
Nelson acc's Avatar
Nelson acc
FTE Sponsor
If I can help, let me know
888-267-7464
Nelson
Old Nov 14, 2007 | 08:55 AM
projectSHO89's Avatar
projectSHO89
Read the TR code on your door sticker then look it up using the decoders available on this site.
Steve
Old Nov 14, 2007 | 04:44 PM
Modified 99
I found out I have the 4R100 in my 99 Expedition 2WD. There is NOT a drain plug in the pan. The TR code on the door sticker is "E". Where are the decoders located? Where can one find out the total capacity of the Transmission and Torque converter?
Old Nov 14, 2007 | 04:46 PM
Nelson acc's Avatar
Nelson acc
FTE Sponsor
You should be able to give any dealership your code or vin and they can tell you
Old Nov 14, 2007 | 05:55 PM
hokiebob's Avatar
hokiebob
My 99 has the "E" code and does have a drain plug and Mercon on the dipstick. I changed the fluid this weekend and it took ~13 quarts total--draining the pan and converter. Was very easy with the drain plugs but would painful with out. Note that Ford has a TSB out now that Mercon V is backward compatible with Mercon--actually, companies can't even license Mercon fluid anymore so if you see some, be very wary that they are not licensed and may not have been through the proper testing and approval process. Mercon V is a much better fluid--better frictional characteristics and low temperature properties.
CMGALLAMORE
1997 - 2003 F150
Jan 16, 2026 01:34 AM
Mark Kovalsky
Dec 20, 2015 10:28 PM
ydoc23
Jul 6, 2012 10:45 AM
eviljarv
Oct 6, 2006 06:42 PM
inoverdrive
Modular V10 (6.8l)
22
Aug 26, 2006 11:06 PM
