Newbie Question
Old Nov 12, 2007 | 11:52 AM
TurtleRacing's Avatar
TurtleRacing
PSD Addict
Newbie Question
I need some advice, I just got my '02 F 350 and I've been reading this forum for quite some time researching. Pics here; https://www.ford-trucks.com/forums/6...and-03s-4.html
Now that I have my truck, I would like to know where my $$ would be best spent first.
I already have a 6637 on it's way, I will do the CCV at the same time, My question applies to after these mods.
I can't help but think that gages would be the smart thing to do next, just so I can monitor anything I do afterwards?
Are there anymore cheap mods I need to do before going to the tuner and axhaust? I'm pretty well sold on the DP tuner and not sure which exhaust yet though. Also, which should I do first, exhaust or tuner?
Old Nov 12, 2007 | 11:57 AM
just another truck's Avatar
just another truck
Exhaust will all depend on what you want to hear, you can see on my sig, i did nothing more then a muffler, others run up to 5" pipes. So, me, first would be the gages, then everything elese. just to watch your base line change as you go...
Old Nov 12, 2007 | 12:06 PM
ron's power stroke's Avatar
ron's power stroke
in my sig is the mod's and fixes link...quite a few mod's too choose from...have fun..i can feel PMS in the air..
Old Nov 12, 2007 | 12:11 PM
TurtleRacing
PSD Addict
Yep, I've spent alot of time already trolling through you sig
Old Nov 12, 2007 | 12:15 PM
ron's power stroke
gauges is a must have..then air intake and exhaust..from there it all depends on where you want to be..you can do a DP then fuel..or you can do fuel, turbo, injectors then the DP....
Old Nov 12, 2007 | 12:19 PM
TurtleRacing
PSD Addict
Do I really need a gage for tranny since the truck already has that? I was thinking about a 2 pod or a 3 pod with something else in teh third.
What do you mean fuel? What is that mod?
Old Nov 12, 2007 | 12:22 PM
ron's power stroke
i would get a temp gauge..the stock one reads in the red when it is too late..when you put a gauge in you will see what i mean when you compare the two....most of us do the intank mod..it moves the return fuel away from the pick up tube inside the tank..that way you get all fuel and no air..it will make your injectors a lot quiter...
Old Nov 12, 2007 | 12:27 PM
ron's power stroke
here is the kit
http://www.itpdiesel.com/store.php?c...on=show_detail
Old Nov 12, 2007 | 12:38 PM
TurtleRacing
PSD Addict
Thanx for the link.
DO you have disconnect the stock tranny gage to hook up the aftermarket?
Old Nov 12, 2007 | 12:41 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Originally Posted by TurtleRacing
Thanx for the link.
Nope. There is a port on the left side of the trans that your new temp probe will go into.
Old Nov 12, 2007 | 12:42 PM
TurtleRacing
PSD Addict
Thanks!
The amount of information on this forum is great, overwhelming but great!
Old Nov 12, 2007 | 12:43 PM
Texas Outlaw
Not a liberal...
No problem. Let us know if you need a pic of the port. It's in the front on the left side.
Old Nov 12, 2007 | 12:56 PM
TurtleRacing
PSD Addict
Thanks.
So you guys think I should get the gages b4 I do the air filter and CCV? Just for monitering purpouses?
Old Nov 12, 2007 | 01:02 PM
rad1026's Avatar
rad1026
Turtle, my theory in mods was to start with the nuts and bolts first and see what kind of differences I could make without spending a ton of money. While gauges are a necessity and I have them now I started with the fuel delivery. By far the Hutch and Harpoon mods have made the biggest difference in the quietness of the injectors and idle smoothness. It was a night and day difference for very little money. ITP has a good kit with a nice custom filter bracket. Next I took care of the dead end fuel rails with the kit from http://www.dinofuelalternatives.com/products.php?cat=17
That also made a huge difference in injector noise reduction and at the same time you can add a fuel pressure gauge to the fuel bowl and shim your fuel pressure regulator to bring up the fuel pressure if you need to.
Next I changed over to synthetic oil. My truck is very happy.
I've done a number of other things, Crankcase vent trap, coolant filter, 6637 and gauges in order to get ready for a chip, but I wanted to make sure these other things were taken care of first. I have two other guys in my neighborhood with 2002's and by far mine is the quietest, smoothest running of the three.
good luck.
Old Nov 12, 2007 | 01:11 PM
Hiflyer746's Avatar
Hiflyer746
I don't think my engine likes synthetic too much. . . its always puking it out somewhere
Tim
