Sponsored by: Real Truck
Headlight replacement
Old Nov 12, 2007 | 07:24 AM
joeyj's Avatar
joeyj
what is the best,brightest replcement bulb for the headlights on a 2005 f250,an where can you get them,i think its a h13 bulb>
Old Nov 12, 2007 | 09:15 AM
empiretc's Avatar
empiretc
anywhere really- walmart, autozoo, oh-rye-lees, etc... They are 9008/h13. You should consider putting in some silverstars.
Old Nov 12, 2007 | 02:15 PM
dfuser's Avatar
dfuser
You want to upgrade the harness and add silverstars for best results. We carry both of those in stock. Shhot me an email, call, an a PM.
Bill 512-750-7102
dfuser.com
Old Nov 12, 2007 | 02:59 PM
ffadragon's Avatar
ffadragon
Is it the same number for a 2004?
Old Nov 12, 2007 | 03:03 PM
dougc's Avatar
dougc
x3 on the silverstars
Old Nov 12, 2007 | 03:06 PM
dfuser's Avatar
dfuser
NO, the 2004 uses 9007 bulbs. There is also a harness for those, not only it increase voltage to the bulbs but also allows you keep the low beam on when you turn the high beam.
Old Nov 12, 2007 | 03:20 PM
ffadragon's Avatar
ffadragon
Thanks Defuser. Do I have to get a new harness or can I just replace the bulbs?
When I went to silverstars website they have like differnt type.
Silverstar Hallogen
Silverstar Xenarc
Silverstar Coolblue
Silverstar Hallogen Xtravision
Silverstar Hallogen Plus
Is there one that is better for superduties than the other?
I need better night vision
Thanks
Old Nov 12, 2007 | 03:38 PM
dfuser's Avatar
dfuser
You do not need the Harness, but if you really want brighter lights trhe harness can increase you light out out by as much as 20%.
I'd go with the silverstars only. I have them in stock if you need a set.
Old Nov 12, 2007 | 04:04 PM
Beerstalker's Avatar
Beerstalker
I prefer the Sylvania Xtravision bulbs. They have pretty much the same light output as the Sylvania Silverstars, but they don't have the blue coating to make the light seem more white. The white light tends to glare more at night. They are also usually cheaper.
I do recommend dfuser's upgraded wiring harness as it definitely made a noticeable improvement as well.
