I am playing with the idea of towing a 2,200 lb fwd car from Washington state to Ohio (2,600 Miles). It would be with my 94 Ranger Extended cab XLT 4.0 5sp. The car would be on a tow dolly and would involve driving through the mountains.
I personally would prefer a trailer over a dolly any day, and you will possibly be a shade underpowered for the mountains, but if you take your time, it can be done. Best way is if the dolly also has brakes, otherwise, pretty dicey.
I would prefer a trailer too but that would be additional weight for the truck to pull. I don't own a dolly so I would have to rent one from uhaul and those ones don't have brakes.
If that is all it truly weighs it is an okay idea as long as you drive slow and take your sweet time coming down the mountain.
You will be basically pulling a 3,000 pound trailer with poor directional control on an extremely long trip.
Some car dollies DO come with either electrical or surge brakes (Uhaul). Search them out.
I have tow dollied Taurus cars behind my F-100 390 granny four speed up and down GA "hills". Going up wasn't so bad, braking coming down was, especially on a downward curve.
So, go slow, especially coming down the mountains, and use 3rd gear.
Just wondering, what is your rear end ratio and is it a 4x4?
If you have a 3.07 rear end, you might want to skip the idea.
Dumb idea or OK idea?
I towed my Dad's 98 4x4 Explorer with my 99 Ranger (4cyl 5spd), with a U-Haul tow dolly. I just didn't do it for very far. We towed quite a bit (probably more than we should have) with my Dad's Explorer with the 4.0L. I'm not sure any of that helps you much. You can go to U-Hauls web site and they have a web program where you put in the towing vehicle information and the towed vehicle information and it will give you what equipment you need and if they think you can do it. If I recall correctly, U-Haul tow dolly's don't have surge brakes but their trailers do.
But I mainly replied cause I noticed you said you were towing a 4wd car. Check your owners manual carefully about towing it. I have a 4wd Camry. The owners manual says you can tow it with the front wheels up for short distances at 45MPH. But if you want to tow it long distance at any reasonable speed, you must put it on a trailer or you will ruin the 4x4 transfer case. My Dad's Toyota RAV4 simply cannot be towed with wheels on the ground period, without damaging the transfer case.
I don't know what type of 4wd system your car has, but you don't want to mess it up.
I went through those mountains a few times, at times doing about 20 mph or maybe less uphill with a big trailer. As long as there's no significant amount of snow on the road and you're careful going downhill (use the same gear both downhill and uphill) it should be no big deal. Make sure your cooling system works good.
Be careful in the mountains, other than that you should not have any problems at all. Don't be in a hurry, check the straps when you stop for gas and food.
My Ranger was a 2001. Same engine with 4:10 rear gears, and it was 4WD.
I pulled a 2900# total weight, tent camper. It done great for a small truck. Except when it had to pull a grade of 4% or more. I pulled 10% grades with this set up. But to do so I shifted into 4wd LO in 2nd gear. I mean you are talking 20MPH!
Yes the Ranger will pull, but a car on a dolly? Yes in the flats, but uphill, unless you have 4wd LO don't try it.
Ya, ever been pulled backward down a hill by a trailer, you could not get rid of!
i have pulled many cars with my wifes explorer w/ a 4.0l using a trailer. never had any problems at all. i am impressed with how well it does. we don't have any moutains in ohio but there are some pretty serious hills. i don't know if there is a big dif. with sohc engine vs the old 4.0l, also the 5speed auto trany vs the 4 speed.
