95 E-150 No Spark
Old Nov 11, 2007 | 09:52 AM
jrozman1's Avatar
jrozman1
Question 95 E-150 No Spark
I have a 95 Van with the 302 engine. The truck is stored down in Florida all year and we only use it for vacations.
There was no spark between the coil and the distributor so I replaced the coil and I still don't have spark. I tested the wiring and there appears to be power (12v) to the coil. Any ideas?
Old Nov 11, 2007 | 11:04 AM
subford's Avatar
subford
Pull the SPOUT jumper out and see if you now have spark.
If so you have bad wiring (short to ground) from SPOUT to PCM Computer or Bad PCM Computer.
If no spark then it would be bad Ignition Wiring, ICM or PIP sensor.
Your ICM should be a Black one, if you replace it do NOT buy a GRAY one or let anybody put a Gray one in.
If it is the PIP sensor then the easiest way is to replace the distributor itself as it comes with one inside.
PIP - Profile Ignition Pickup
ICM - Ignition Control Module
PCM - Powertrain Control Module
SPOUT - Spark Output Signal from EEC
Old Nov 11, 2007 | 09:03 PM
Club Wagon's Avatar
Club Wagon
Reluctantly, I've grown to trust the onboard diagnostics & now consider the use of Fault Code Readers to be fundamental. IMO the price I paid for a digital unit was some of the best money I ever spent on any of the 3 Econolines I've owned. The Reader runs a series of checks, the Key On-Not Running mode would probably identify what's wrong.
I've found out the hard way that these complex interconnected systems often hide faults & that throwing components at it logically can be a wild goose chase. I replaced the suspect ICM, PIP & PCM seeking to solve an intermittent violent stammering. Note that I replaced the PIP at a small fraction of the price of buying a new distributor. The local expert FORD mechanic labeled it "Blue Oval Disease", the Stealership mechanic advised that often, even with their resources, what seems to be ignition, winds up being fuel issues! The Fault Code Reader ended up having to be used like a Chinese Fire Drill-jump out & plug it in WHEN the 302 acted up-at which time it showed the TPS at fault!
Very often the computer already knows what's wrong & has the answer stored for you. If I were you, 1st I'd 'ask' your '95 Econoline itself what it 'thinks' is wrong, before seeking opinions remotely.
Also, leaving a vehicle parked for extended time in subtropical FL is a recipe for moisture, bugs and/or rodents to do their mischief. Up north I once had a mouse chew through the wire that energized the alternator, a hard to find fault that stumped several veteran mechanics.
Jim94F150
Sep 20, 2018 11:25 AM
ymirr
Apr 6, 2017 07:42 PM
jkesna
Sep 7, 2013 03:30 PM
pickncrew
Mar 29, 2010 10:51 AM
tjs_79ford
Sep 20, 2009 11:30 AM
