Sponsored by: Real Truck
Air Springs
Old Nov 11, 2007 | 08:04 AM
RoyAnger's Avatar
RoyAnger
Air Springs
I am trying to add load support and sway control to a 2007 Ford F350 DRW truck carrying a truck camper.
What are the pros and cons of air springs mounted inside the rear springs like the Arnott Air Ride kits vs the ones mounted outside the rear springs like the Air Lift Load support kits. Also the pros and cons of drilling vs no drill kits.
I have heard the ones like the Arnott Kits do not control sway and in some cases may even cause it because they are too close together because they are mounted inside the rear springs vs the Air lift that are outsde the springs and add width to the load support.
Old Nov 11, 2007 | 08:19 AM
redford's Avatar
redford
FTE Leadership Emeritus
Have you looked into using a set of Timbrens?
http://www.timbren.com/
Old Nov 11, 2007 | 08:35 AM
RoyAnger's Avatar
RoyAnger
I used them on a 2000 F250 I had and they controled the sway very well but did little for the load support.
Old Nov 11, 2007 | 09:52 AM
DCSpecial's Avatar
DCSpecial
The ones mounted to the inside of the frame rail are for if you have a gooseneck hitch.
The ones on the outside, on top of the leaf pack are as wide out as possible and will give the best stability.
No drill kits are easier/faster to install. Drilling takes some time.
I have the Air Lift load assist bags that go on top of the leaf pack. Love the bags, only had to drill 2 holes per side to install them. I've had 2400lbs in the bed and another 600-700 hanging off of the hitch and then leveled it out perfectly...even can keep it slightly azz high like how it sits unloaded.
Old Nov 11, 2007 | 11:03 AM
GregsSD's Avatar
GregsSD
I have the Firestone #2450 which mount inside the frame rails and they look and work great.
I don't haul a slide in camper so I have no problem with sway, if you haul a slide in camper then I could see wanting the outboard bags.
