I6 upgrades
Old Sep 27, 2000 | 11:12 AM
jopey's Avatar
jopey
I6 upgrades
I know here in NY they just look for everything that was installed by the factory.
something missing. it has to be replaced in order to pass inspection
Old Sep 27, 2000 | 06:43 PM
82F100SWB's Avatar
82F100SWB
I6 upgrades
[font size="1" color="#FF0000"]LAST EDITED ON 27-Sep-00 AT 07:46 PM (EST)[/font][p]Other than the forged crank, the HD has forged Pistons(mine are missing...), connecting rods, sodium filled(or is that cooled?) valves, a lower stock compression ratio(8:1.) External clues to identify a HD by are the alt bracket, which has no place to mount an air pump, a solid spacer in place of the EGR spacer, a plug in the exhaust manifold where the egr pipe would normally connect to, and, if it's still in a vehicle, the emissions sticker will have "Non Catalist" written on it. The easiest way to het a HD is to get a 300 out of a F600, as the HD was the base engine in that series. I have a Non Catalist emissions sticker and I am trying to find a replacement for it to put on my truck, if you want the calibration number off of it, I will get it for you on the weekend.
Evan MacDonald
82 F100 FlareSide
HD 300-6, 240 head
Headman Hedder
NP435(6.69 low)
2.73 Geared 9"
Blue & Silver
Old Sep 27, 2000 | 08:46 PM
captntim's Avatar
captntim
I6 upgrades
Thanks Evan...I most certainly have the LD 300 as I have an air pump mounted on the alternator bracket. Also...in another post I read that you get better that 26 mpg??? With all thoes mods, other than a 240 head, how do you do it? On my stock 300 i get 17.2 highway with the three speed with overdrive running 1500 rpm @ 65mph in od. I guess my question is; will modifications including a clifford water heated mainifold with a 390 Holley, a hedman header and straight dual exhaust actually improve my gas mileage?
thanks,
Tim
Old Sep 28, 2000 | 07:22 PM
Motorcraftsman's Avatar
Motorcraftsman
I6 upgrades
my truck has a 300 too, i may a budget modification, i i had two cats on my exhaust i cut the second one off, and ran straight pipe all the way comming out to in front of the rear wheel, ive noticed the motor catches rpms alot quicker than before, now, my question, i had the carter feedback carb on it, ive disconnected all the emmissions crap that runs into it this cause it to blow out enough gas to shoot fire, someone up here suggested a older non feedback carb.... got one on it today, doing this swap really cleaned alot of junk aounr the manifold, but yet its still wasting alot of gas, what can i do here?
by the way, here in this part of nc im not worried about emmision itll pass any time
Old Sep 28, 2000 | 10:37 PM
timpage's Avatar
timpage
I6 upgrades
Tim, adding a header or duel manifolds, 4 bbl carb and intake, and duel exhaust should improve your mileage overall. On the 240 in my 65 F100, my hi-way mileage improved alot, but city mileage didnt improve much, so... be prepared to expect anything if you modify your 300.
Old Oct 5, 2000 | 01:38 PM
82F100SWB's Avatar
82F100SWB
I6 upgrades
How do I do it? Well, I've got it running as lean as is safe, the timing is set by ear to the highest idle(damper is on my truck wrong, can't use a timing light.) And I drive with a light right foot(with gas at $3.17 a gallon, you have to.) I think that running the engine at it's torque peak will make for better mileage(Mine cruises at 60 at 1950 rpm, peak torque is at 2000 rpm.)
Good luck
Evan MacDonald
82 F100 FlareSide
HD 300-6, 240 head
NP435(6.69 low)
2.73 Geared 9"
Blue & Silver
Old Jun 22, 2002 | 11:38 PM
fahad's Avatar
fahad
I6 upgrades
Captntim:
By the way what is side gapping, I am intrested in dong that to my 300-6, I need some power. Thanks.
Fahad.
Old Jun 23, 2002 | 12:13 AM
tetraruby's Avatar
tetraruby
I6 upgrades
Please search "sidegaping" or "sparkplugs" for more information.
Old Jun 24, 2002 | 08:00 AM
Stephens's Avatar
Stephens
I6 upgrades
To side gap, you cut the part of the electrode that you noprmally bend to gap the plug real short. So now it doesn't extend over the center electrode. Then bend what's left of the electrode you cut to the center until you get the right gap (it'll now extend from the side.) Now the spark jumps from the side instead of straight down. This way there's no metal "blocking the spark" from the combustion chamber, the plug is opened up. I think its one of those Carolina Boys dirt track/stock car trick, that I had never heard of either. (they're constantly searching for more HP)
Old Jun 24, 2002 | 09:33 AM
DrFord's Avatar
DrFord
I6 upgrades
timmwag
Jan 1, 2010 10:45 PM
timt2001
New Member Introductions
Oct 7, 2008 06:03 PM
RICHARD CLARK
May 10, 2005 10:37 AM
RJKobbeman
17
Mar 30, 2002 12:41 AM
