61 Uni steering options
Far as adjusting a box if done properly nothing wrong hecks it's better than letting a loose box hammer the gear faces internally. Too tight is flat plain stupid by the person overtightening the box that will wipe it out in no time with uneccessary preloading.
Whats left is on the bench in the vice using a pickle fork if seperation is needed.
And again there is no adjustment for wear....Its bearing preload and if its worn it will move the mesh closer and out of the wear pattern, The cure for wear is repair.
Garbz
I worked on an old old old Case tractor on the ranch the steering box sector gear was so worn away you could of placed a penny flush in the gear teeth.
I Tig welded the teeth back up ground and flap wheeled to looking like new again then had the teeth case hardened. Going on 15 years of light use monthly at the ranch and still a tight box. This was on a dare I bet ya kind of repair, guess ya gets lucky once and a while.
