Had a '75 F250 2wd front disc power brakes, and a '73 F250 4wd Hiboy drum brakes on all 4 no pwr booster. Bought a reman booster for the "73 and noticed it was smaller in dimension (dia mostly)than the '75. Is the difference in the year or the brake config?
I now have a '74 F100 2wd front disc and need to replace the booster I would prefer the smaller one if the effects are tolerable.
Had a '75 F250 2wd front disc power brakes, and a '73 F250 4wd Hiboy drum brakes on all 4 no pwr booster. Bought a reman booster for the "73 and noticed it was smaller in dimension (dia mostly)than the '75. Is the difference in the year or the brake config? I now have a '74 F100 2wd front disc and need to replace the booster I would prefer the smaller one if the effects are tolerable. Anybody else seen or try this?
1974/75 F250 4WD PDrumB ~ Bendix Booster ~ 8.94" in diameter.
-------------------------------------------------------------------------- Which booster does the truck have on it now?
Since autoparts stores sell rebuilt booster/master combinations, you might end up with any of the above...or >>>
>>> There are dozens of boosters and master cylinders for different applications!
------------------------------------------------------------------------ *Master Cylinder p/n: D3TZ-2140-B
Its definatley one of the 11's but cant say wich without removing the master cylinder. This info will certianly help in locatingthe one I want. I was curious to know if this would change braking and the way the petal feels and in what way.
