My latest idea for the van...
For those of you that don't know, the computer in these rigs is located DIRECTLY under the heater core which is located on the passenger's side under the dash. The heater core area is covered with some nasty black sticky stuff that runs around the edges to insulte the computer's area from the heater core's area. But as soon as you remove the cover from the heater core area and remove the heater core itself, the integrity of that nasty black insulation stuff is compromised - meaning that heat in the heater core area makes it's way into the computer area AND a coolant leak in the heater core will result in coolant getting into the computer area....NOT GOOD! I can't help but to not like the way the heater core and computer are situated. I just so happen to have an extension cord of sorts for the computer in my arsenal of Rotunda stuff that is made to ease the installation of a BOB (breakout box)/Monitor that gives me a few feet of length to play with. So, I got to thinking about this. I could easily relocate the computer, hook up a BOB and build some kind of shock proof enclosure. Since I have no passenger's seat in the van, finding a spot for the enclosure wont be hard. Doing this would allow me to get the computer away from the heater core, it would ease the removal/installation of the computer (something I will do every so often with the BOB's and the Monitor while tuning) and it will allow for a permanently installed BOB which I think would be cool. All I would have to do is pop off the top of the enclosure and bust out a meter and away I go. Removing and installing the computer is not only a royal pain in the ***, but doing so regularly will in time wear out the threads in the computer...not good.
So, anyone got any ideas as to how the computer and BOB enclosure ought to be designed? What should it be made out of? I am thinking 1/2 inch plastic, mounted to the body with a removable top, a hole for the cables to enter plus a few breather holes. But how am I going to fasten the computer and the BOB down to the enclosure to keep them from bouncing around? I might even be abl to kill a few birds wit 1 stone and install some of my MSD stuff in this same enclosure.
Time to play engineer...
Sounds like a lot of work for a minimal gain/preventative maintenance.
Seal your ECU and make sure the heater core is in good condidtion.
I bet some insulating foam for $5/bottle would get the job done.
If you run a NON electric controlled tranny (i.e. AOD) ... your ecu is barely worth $100.
I think you guys are missing the point......either that or I am some kind of wigged out nut case.
This project will do all of the following:
1) Allow for a breakout box to be hooked up ALL THE TIME and it will protected...so no shorted out pins.
2) Allow for EASY installation of a monitor.
3) Get the computer away from heat and coolant.
3) Give me a good place to mount my MSD stuff.
I already have extension cords that will allow for relocation, I have no passenger seat so I can use existing holes to mount the enclosure and I have a good source for plastic.
To me this sounds like a good idea.......but I would like some more ideas and opinions.
All the EEC computers are supposed to be on bracketry, which if your vehicle doesn't have you can easily find one in any junkyard. Doesn't necessarily have to be from your specific vehicle but at least adaptable to where your EEC hides.
Since the EEC is essentially a sealed box except for the rubbery j3 port cover on the back, you can enclose it in a waterproof container and not endure any thermal problems.
Even a large, thick-mill freezer bag would work. Tie the end of the bag over the wires on the connector!
i've seen a pic of a newer dually econoline that looked pretty slick - searching now
EDIT: bingo
https://www.ford-trucks.com/user_gal...?albumid=30054
...and another
https://www.ford-trucks.com/user_gal...131881&width=0
EDIT: bingo
...and another
