shocks install
Old Nov 9, 2007 | 07:48 PM
Siggy1's Avatar
Siggy1
shocks install
I have a 07 f-150 crewcab, when i started to upgrade the front shocks I was surprised by the springs. do I need a spring compressor to install new shocks?
Old Nov 10, 2007 | 02:43 AM
rootdenied's Avatar
rootdenied
Yes, I had to go through the painful procedure of changing the front struts. You will need a strut compressor to remove the springs from the old shock assembly. Also the easiest way to remove everything is to disconnect the steering arm so the whole assembly pulls out easily.
