A BIG thanks to FoMoCo for hidin that 3rd starter mount bolt way up in there.....
I have a 2000 F250 4x4 SD crew v10.........just had to replace the starter mainly due to all the chemicals they put on the roads here in Ohio. It wasted the little solenoid contact strips.
Also, without the fire wrench those stubborn coroded bolts would never have came out of that aluminum bellhousing.
Good luck in all your first time starter removals....especially here in the rust belt.
