cold water leak
Old Nov 9, 2007 | 11:45 AM
robbieharp's Avatar
robbieharp
cold water leak
Is anyone having a problem with water leaking out the top hose when the temp drops a little (truck is cold 2004 6.0). If so whats the damage and if theres a lot of this happening why is this not a recall Item?
Old Nov 10, 2007 | 02:16 AM
riggz's Avatar
riggz
What top hose?
Old Nov 10, 2007 | 01:49 PM
robbieharp's Avatar
robbieharp
water is coming from the top back side of the motor and running down the transmission bell house. I'm not sure exactly where it is coming from. its not a lot and it only happens when it is 40 degrees or lower. can you shed some light?
Old Nov 10, 2007 | 03:04 PM
blackhat620's Avatar
blackhat620
EGR cooler hose is leaking, it is under the 5/100k warranty. Take it and let them change the hose, btw the new updated hose that is supposed to last longer.
Old Nov 12, 2007 | 05:30 AM
robbieharp's Avatar
robbieharp
Thanks a million!
