Has any one ever did this swap.... does the 8.8 disk brakes swap over, drive shaft? Aparently my rear gears are going south and i have a few 9.75's to throw in.... hopefully this is an easy swap...
Disc brakes don't swap over....And you might need a new driveshaft since the 9.75 is longer than the 8.8 (or source one from a truck in the junkyard with the same wheelbase)
Disc brakes done swap over? If the 9,75 has em and my 8.8 has em.... why wouldnt things work.... what dosnt work.... if i use the 9.75 drive shaft it should be aight... i have both...
You had me confused. A disc brake swap is when you put disc brakes on an axle that origionally came with drum brakes. If your 9.75 already has discs, then you will be good to go
And yeah, as long as the driveshaft came out of a truck with the same wheelbase, then it should fit just fine as well. I.E.: A regular cab short bed's DS will not interchange with a super cab short bed's DS...
No Problem I did mine a while back just had to take 11/2 inches of my d/s balance it and away I went. still have to do the front but thats going to happen in the spring. got that one too both for 300 bucks
