starting question PLEASE!!
Old Nov 8, 2007 | 03:18 PM
codys50ford's Avatar
codys50ford
I have been having starting problems with my 1992 f350 diesel. I just changed my glowplugs and relay and i am still having problems. The glowplugs just come on for a second and turn off, i cant get them to come on and stay on the designated amount of time. I use my truck for work and really only have this evening to get it fixed...If anyone can please help please respond. Thanks guys
Old Nov 9, 2007 | 08:56 AM
starmilt's Avatar
starmilt
I like going with manuel switch but some guys don't. I would start with making sure it is grounding good.
Old Nov 9, 2007 | 11:45 AM
PLC7.3's Avatar
PLC7.3
Changed the glow plugs .. what brand did you use.....
If you have 2 or more bad GPs, the controller may not cycle at all.
Two problems that occur with the solid state ( 1987 to 1994 IDI engines ) GP systems. If a GP burns out ( circuit resistance goes up ), the controller cycles the GPs at a faster rate which doesn't let them get to max operating temp. If 2 or more GPs fail, the controller may not cycle the GPs at all ( very rapid or no clicking heard ). When you check the GPs, use an ohmmeter. A high resistance ( not necessarily burned out ) GP can cause circuit resistance to go up and the controller will then cycle the GPs too fast. You probably will not find this problem with a test light. Resistance spec for GPs = .5 to 1 ohm cold. Second problem. A poor controller ground ( black wire attached to valve cover stud ) will cause the controller to leave the GPs on longer, often damaging or failing them. If you are having mulitple GP failures, I would check closely the controller ground. Now the confusing part. Bad ground --> longer GP on time ( slower cycling ). Burned out GPs --> faster cycling If you have both situations, it may appear that the controller is cycling the GPs at the proper rate. Bad ground slows it up while the burned GPs speed it up ---> normal cycling. The system acts/sounds like it's working normally, but you have a hard starting concern.
By........DieselDon
Glow plug torque is 12 ft lbs, I always use antisieze on the threads.
