1994 F-150 charging problem
Old Nov 8, 2007 | 01:52 PM
kingcavinee's Avatar
kingcavinee
3G alt
Base voltage 12.70
Charging 14.56 volts
With the engine running the volt meter in the dash reads close to 18 volts
I replaced the battery, voltage regulator and brushes.
I have no idea what the problem is.
Also had the alt checked at AutoZone checked ok.
Replaced the battery because it was getting weak,
possibly due to over charge?
Anyone have any thoughts on the problem?
Old Nov 8, 2007 | 03:26 PM
ynevada's Avatar
ynevada
faulty guage?
Old Nov 8, 2007 | 03:34 PM
kingcavinee
i am assuming the gauge works, with key on engine off it reads normal
also battery light is on
Old Nov 8, 2007 | 03:36 PM
ynevada's Avatar
ynevada
it works, but is it accurate? id try another guage. or a volt meter should work.
just to be sure.
Old Nov 8, 2007 | 06:43 PM
Franklin2's Avatar
Franklin2
[QUOTE=kingcavinee]3G alt
Base voltage 12.70
QUOTE]
You measured the voltage at the battery and it was 14.56v, but at the same time the gauge in the dash is reading 18v? Definitely sounds like a gauge problem. 14.5 volts is perfect at the battery.
