Sponsored by: Auxito
2'' add a leaf question
Old Nov 8, 2007 | 12:48 PM
DaBossF250's Avatar
DaBossF250
I found a 2'' add a leaf for a good price but it said for F150 97-03 4X4 trucks. My truck is a 99 f150 2WD, will this still fit my truck or not since my truck is a 2WD?
Old Nov 19, 2007 | 10:00 PM
DaBossF250's Avatar
DaBossF250
anyone know if this will fit my 99 2WD F150??
Old Nov 20, 2007 | 02:40 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
It should...I don't see why it wouldn't? To my knowledge, the only difference between the 2WD and 4WD rear suspension, is that the 4WD has a 2" block.
Old Nov 21, 2007 | 09:22 AM
djfordman81005's Avatar
djfordman81005
yeah...all leafs are interchangable. F150, 250, 350 & Excursion will all bolt right up. I believe the length is 57"
Old Nov 21, 2007 | 10:53 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Uhhh...no, they won't. SD's and X's have 3" wide leaf springs, and I'm pretty sure they are longer. F150's are shorter and only 2.5" wide.
Old Nov 21, 2007 | 11:00 AM
djfordman81005
of course they are wider thats part of the reason they are stronger but the length is the same....its been done
