Another "Clunk" in Drivetrain
Old Nov 8, 2007 | 11:35 AM
Craig64's Avatar
Craig64
I lubed my driveshaft slipjoint about 9 months ago and it cured that dreaded "clunk". Same type of thing's returned.
Is it common to have to relube that slipjoint every year?
Thanks. Craig
Old Nov 8, 2007 | 11:39 AM
WonderDonkey's Avatar
WonderDonkey
I am unfamilier with this, i didnt know i needed to lube it ever.
Old Nov 8, 2007 | 12:24 PM
1996pwrstrk's Avatar
1996pwrstrk
It's very possible I have to lube my dad's 02 slipjoint every 7 or 8 months been thinking of just drilling and putting in a zerk fitting.
Old Nov 8, 2007 | 12:30 PM
empiretc's Avatar
empiretc
yep, what dave said. I have lubed mine twice in 2 years. Next time it comes down, I am putting a zerk in it.
Old Nov 8, 2007 | 12:45 PM
WonderDonkey
How and what exactley are you lubing?
Old Nov 8, 2007 | 12:53 PM
1996pwrstrk
The slipjoint on the rear driveshaft. Remove the driveshaft from the rearend and pull the slip joint apart grease the splines .
Old Nov 8, 2007 | 12:56 PM
Craig64's Avatar
Craig64
Thanks guys, I'm hoping that's all it is.
I've got a link at home that I'll post tonight. It's basically a splined joint in the driveshaft (male / female) that sits inside a rubber boot on the rear half of the shaft. You pull the clamps, push the boot back unbolt the shaft from the differential and drop the shaft to grease the splines.
I was experiencing a little slack in the drivetrain from dead stop and when it got really bad I even felt a little bump when rolling to a stop. I lubed it with teflon grease 8-9 months ago and the drivetrain completely tightened up. Now that slacks back. Craig
Old Nov 8, 2007 | 01:54 PM
03_PSD's Avatar
03_PSD
wow, good to know, thanks guys!!
Old Nov 8, 2007 | 08:35 PM
Craig64's Avatar
Craig64
Here's a great link with pictures of the yoke:
http://www.eurekaboy.com/f250/slipjoint.htm
Old Nov 8, 2007 | 08:53 PM
Whit350's Avatar
Whit350
That is helpful because I have the light clunking too. I have only had this truck about 6 months and I am getting used to the clunk.
Old Nov 9, 2007 | 08:46 AM
03_PSD's Avatar
03_PSD
thanks for the link Craig64!!
Old Nov 9, 2007 | 11:50 AM
Fat Diesel's Avatar
Fat Diesel
This is what was deemed the best grease for the job about five years ago or so. I've used it with success.
MikeTEC
Oil & Lubrication
Feb 12, 2014 06:38 AM
DRM2004
2004 - 2008 F150
28
Feb 21, 2013 01:34 PM
kermmydog
Arizona Chapter
Aug 29, 2008 10:37 PM
Craig
Jan 26, 2002 10:00 PM
