Is there any difference between...
Old Jul 23, 2002 | 01:44 PM
JCDXJ's Avatar
JCDXJ
a 300ci efi block(1990) and a 300ci carb block (1980)? What about the heads? I have a 1990 truck and the engine is bad, I have a line on a 1980 truck with the same engine with 88k miles(original) that runs well, can I swap the blocks, (and) heads?
Thanks,
Jason
Old Jul 23, 2002 | 02:42 PM
FordPerf300's Avatar
FordPerf300
I don't see why they wouldn't be the same, but then again... things change.
Old Jul 23, 2002 | 03:14 PM
brown 4x4's Avatar
brown 4x4
The 1980 block will have the hole from the mechanical fuel pump which you won't need with EFI, but I think you can cover this somehow. The 80's carbed 300's didn't have holes in the head for air injection, EFI'd ones did.
[font color="green"]1995 F-150 Supercab XLT 4x4 302 M5OD 8' bed [/font]31x10.50's
[font color="green"]1986 F-150 4x4 300 I6 NP435 [/font]Warn hubs, DeeZee bed caps, '96 XLT bench seat, new paint job
Old Jul 23, 2002 | 04:07 PM
JCDXJ's Avatar
JCDXJ
So, from what you're saying, I could use the block from the 80 and the head from the 90 should bolt on? This way I could have the holes for air injection in the head and just get a cover plate for the fuel pump hole? COOL
I hope it is right.
Thanks,
Jason
Old Jul 23, 2002 | 05:54 PM
brown 4x4's Avatar
brown 4x4
That should work.
Old Jul 23, 2002 | 10:16 PM
ecarter50's Avatar
ecarter50
The knock sensor will not fit in the early block. I rethreaded the sensor and used an adapter fitting. The fuel pump blockoff for a chevy will fit.
Old Jul 24, 2002 | 07:55 AM
JCDXJ's Avatar
JCDXJ
Could you maybe explain a little more, please? How did
you rethread the sensor and what type of adapter did
you use?
>The fuel
Thank you ecarter50 and brown 4x4
Now, in a couple of weeks, the fun begins!!
Thanks again,
Jason
Old Jul 24, 2002 | 08:13 PM
ecarter50's Avatar
ecarter50
The block has a pipe plug in the correct location. I rethreaded the sensor to 1/8 27 NPT and used a mechanical oil pressure fitting to adapt the size.
Old Jul 25, 2002 | 08:16 AM
JCDXJ's Avatar
JCDXJ
Thanks, this should go easier than I expected.
This site is great!!
Jason
Old Jul 25, 2002 | 08:31 AM
kameleon's Avatar
kameleon
