idle problem
Old Nov 8, 2007 | 08:35 AM
92fordman's Avatar
92fordman
idle problem
the problem occurs when the truck is in gear and it has an underdrive puuley on and as i come to a stop the amp gauge gos down a lot but i hit the gas and it go up.its a 92 f150 5.0
Old Nov 8, 2007 | 09:14 AM
akaGWall's Avatar
akaGWall
At idle your underdrive pulley is probably not spinning the alternator fast enough.
Old Nov 8, 2007 | 10:52 AM
92fordman's Avatar
92fordman
i have the idle right at 1000 i would think that would be fast enough or the alternator is bad
Old Nov 8, 2007 | 10:57 AM
92fordman's Avatar
92fordman
does anyone have any ideasabout this its driving me nuts .the alternator had a burnt wire but i fixed it and it ran really good for about a week and its doing all over again
Old Nov 8, 2007 | 03:09 PM
lostin90s's Avatar
lostin90s
With stock pulley set up it would .DId you get the 3 pc pully set or 2 . The 3 pc works better than according to a guy I put a MAF setup on. Good luck
