GAS LEAK!!!!!
Old Aug 1, 2002 | 10:07 PM
muddogin400's Avatar
muddogin400
GAS LEAK!!!!!
I have a 1984 bronco with a 300 in it. last week i started it up to go to work like every mornign but in stead of it runnging tough like it always has it ran ruff as #####. i stoped at a gas station and poped the hood. i had raw gas running out of teh bottom of the carb. i took teh truck home and pulled the carb off and inspected it real good. nothing seemd wrong so i went ahead and rebuild it. it worked for 2 days fine but teh other day gas is once again leaking all the way around the base of the carb. has anyone had this problem before. i am at the end of the line i have tired everything to my knowlage. any suggestions will be helpful.thanks
Old Aug 2, 2002 | 07:18 AM
Stephens's Avatar
Stephens
GAS LEAK!!!!!
Any chance of it being a float valve that gets stuck?
Old Aug 2, 2002 | 11:13 AM
larry derouin's Avatar
larry derouin
GAS LEAK!!!!!
>helpful.thanks
That's one of the nastier manifestations with the Carter YFA. However it CAN be rectified. Pull the carb off the engine. Flip it upside down and remove the bolts from the base to the body. Wire brush the threads on the bolts. When clean, coat in Locktite and install. Torque down fairly tight. Flip the carb back over and reset the float level. I usually set the upper limit a 1/16" lower than what it calls for and never had one overflow yet. Make sure that the float is not actually saturated(poly) or ruptured and filled(brass). If it floats in a bowl of gas you're ok, if it sinks, then you'll have to replace the float.
DO NOT USE SILICONE GASKET MAKER on the carb gaskets. They need to be dry(no filler!)
I believe Holley makes a direct replacement (or at least they did a few years back) for the YFA. If I can find the # I'll post it.
Larry
Old Aug 2, 2002 | 09:26 PM
optikal illushun's Avatar
optikal illushun
GAS LEAK!!!!!
