cylinder
Old Nov 7, 2007 | 11:47 AM
17fordguy's Avatar
17fordguy
cylinder
well im rebuilding my motor its got nearly 150000 miles on it the cylinder walls look like this
does this mean that the motor has been rebuilt before?
Old Nov 7, 2007 | 05:26 PM
ford_boy_1996's Avatar
ford_boy_1996
No...... it means your cylinders look good
Old Nov 7, 2007 | 07:06 PM
ACarbone624's Avatar
ACarbone624
Those lines mean it was "honed" (hoe-n-d) properly after machining....looks good to me.
Old Nov 7, 2007 | 07:20 PM
hodernyf150's Avatar
hodernyf150
those walls look good to me the honing lines are still there
Old Nov 7, 2007 | 07:43 PM
Robustus's Avatar
Robustus
Just out of curiosity, why did it need a rebuild at 150,000mi? What happened?
Old Nov 7, 2007 | 07:53 PM
TheRoadVirus's Avatar
TheRoadVirus
Yea, that's cross-hatching.. helps the rings seat properly. Looks like it's in good condition, lucky you.
Old Nov 7, 2007 | 07:56 PM
flareside_thunder's Avatar
flareside_thunder
Don't think I've seen anything with 150,000 on it with that good crosshatching.......
JR
Old Nov 7, 2007 | 08:03 PM
danr1's Avatar
danr1
JR
No me either, completely worn off by then. Even at half that mileage.
Must have been well cared for, oil changed regularly with good oil used.
Old Nov 7, 2007 | 08:09 PM
17fordguy's Avatar
17fordguy
rebuilding it to put in new cam and such and i doubt this truck was well cared for before i got it and was suprised to see the marks when i pulled it all apart so i figured that some one else had pulled it apart pefore and was just getting yalls op[inions on it
Old Nov 7, 2007 | 08:14 PM
flareside_thunder
I'm gonna be the bad guy and say yes It has been gone through...no way would it have that mileage and look that good.....
JR
Old Nov 7, 2007 | 08:15 PM
danr1's Avatar
danr1
It could have been but not a home spun job.
Does it have a rebuilder tag on it, "Jasper" or like reman would have a tag on it down low near oil pan/bell housing area.
Old Nov 7, 2007 | 08:19 PM
17fordguy's Avatar
17fordguy
nope nothin like it seems that every thing is stock gonna get a dial and measure the width of the cylinders to see if it was bored out
Old Nov 7, 2007 | 09:01 PM
EPNCSU2006's Avatar
EPNCSU2006
I know this is apples and oranges, but I rebuilt an old honda with almost 190000 miles on it still had the original cross hatch. I don't think it's out of the question to still be able to see the cross hatch at 150000 miles.
Old Nov 7, 2007 | 09:39 PM
BEWOLD's Avatar
BEWOLD
I tore down my 89 crown vic 5.0 with around 250000kms, It still had a good cross hatch! the only reason I tore it down was cause the trans literally exploded (case split just about completly in half) so I pulled the engine and junked the rusty car (should have kept the 8.8 as well).
Old Nov 7, 2007 | 10:26 PM
Robustus's Avatar
Robustus
Again, apples to oranges and all, but I've seen lots of old Volvo engines at the junkyard with good cross-hatch and 200,000+ miles on the odo...
