F250 - No Engine Braking
Old Nov 6, 2007 | 11:01 PM
Wayno's Avatar
Wayno
Hello All,
My first Ford HD, so you guys are a Godsend. Bought 2001 F250 used so unclear on history. Bought at 110K, Trans scattered at 121K. "completely" rebuilt. Shifts fine but no engine braking. Trans shop said all OK as far as the trans goes. Maybe the chip. Took to Ford, there was a super chip of some kind, but as no controller came with truck, I had Ford restore to spec. Still no engine braking. The Ford tech mentioned a "one way clutch" which I'm guessing is a " coast clutch. I believe that when I manually drop a gear, the tach should show higher RPM and track slowly down as the truck loses speed. I gotta take it back to the Trannie shop, and it sounds like their going to have to tear it down again. Any comments, insights, advice VERY welcome!
Old Nov 7, 2007 | 05:05 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Welcome!!!
I am guessing it is a diesel - but am not sure. Check out the relevant engine forum, as well as the Superduty forum, and don't be afraid to post up your problem in there!!!
Good luck - and don't forget to check out Karl and the rest of the crew in the Northern California chapter!!!
Old Nov 7, 2007 | 02:18 PM
Wayno's Avatar
Wayno
Hello FTE Fred - yea sorry, it is a 2001 F250 4WD Crew. I'm thinking 4 speed w/OD. The VIN plate at the bottom shows "TR 9". The VIN decoder doesn't get to that level of detail. Gotta figure out how to get truck specs into my post automatically as most of you do.
I posted on the Engine and HD forums as you suggest
Thanks again!
anderson123
New Member Introductions
Jul 18, 2016 04:15 PM
bazookabrown
Jan 1, 2005 07:14 PM
