Modular V10 (6.8l)
coolant change
Old Nov 6, 2007 | 09:02 PM
rainmaker262's Avatar
rainmaker262
coolant change
Can anyone give me some pointers on changing coolant in my 2000 f-350 v10, also it apears my temp sensor has gone.. 160.k on her..
Old Nov 7, 2007 | 12:59 AM
Monsta's Avatar
Monsta
Sit. Stay.
Open the drain **** on the bottom and let it drain into a hole in your backyard. I put mine right next to where I change the oil.
Refill with 50/50 water/coolant of the correct specification found in the back of your owner's manual.
You can flush it with a kit found at most automotive stores or one of the 'Mart stores.
Old Nov 7, 2007 | 07:23 AM
BareBones's Avatar
BareBones
Monsta!! You can't talk like that - this is a Family Channel ! Cities in Minnesota have recycle centers where you can drop off your coolant and oil for disposal. Besides, the old ethelene glycol is poisonous and evidently sweet, as it does a real number on pet dogs/cats and the occasional baby.....
Now the new biodegradable gold stuff is a little safer.
Old Nov 7, 2007 | 06:10 PM
Monsta's Avatar
Monsta
Sit. Stay.
Oh yeah, I forgot...after I drain the coolant I get a basket full of puppies and place them next to the hole to clean up any that doesn't soak in fast enough.
I take it you didn't realize I was joking?
Old Nov 7, 2007 | 08:44 PM
rainmaker262
gotta figure out how to get the coolant inside for the cats
Old Nov 7, 2007 | 08:48 PM
Wrenchtraveller's Avatar
Wrenchtraveller
I thought you were serious as we all know that Hawaii has molten lava a few feet down and this would burn up all your coolant and used oil. Here on beautiful Vancouver Island dumping coolant is more serious than robbing a bank. I like your sense of humour.
Keep up the great posts.
Old Nov 7, 2007 | 08:55 PM
BareBones's Avatar
BareBones
Sure Monsta, I knew you were joking - It was Rainmaker I wasn't so sure about.....
Old Nov 7, 2007 | 11:05 PM
Monsta's Avatar
Monsta
Sit. Stay.
Molten lava? Now there's a thought... I could just take it to the Volcano instead of the auto shop down the street!
Old Nov 8, 2007 | 12:09 AM
Bdox's Avatar
Bdox
He was gonna bury it with dirt. Then he remembered that they don't have any!
Old Nov 8, 2007 | 07:52 AM
MarkMoore's Avatar
MarkMoore
Um, I don't think that will cool the volcano, but it may keep it from freezing
Old Nov 8, 2007 | 11:33 PM
biz4two's Avatar
biz4two
Arrow
Drain both the radiator and reservoir bottle. Next you can purchase a pre-mix of 50/50 coolant with distilled water and fill-up the radiator first. Then fill the reservoir bottle 3/4 and with both radiator and reservoir caps on loosely...start the engine and turn the heater to defrost. This will allow the coolant to start flowing the entire system and get any air bubbles out. Once you get the V10 up to normal temp...shut down and check coolant level. Top off as necessary. Tighten the caps...and off you go.
OBTW: With a 2000 V10...you get the GREEN coolant. Stay away from the "Orange" and "Gold" (yellowish color).
Hope this helps...
biz
Old Nov 9, 2007 | 03:51 PM
rainmaker262
thanks guys
Old Nov 9, 2007 | 07:27 PM
Sport45's Avatar
Sport45
It's also acceptable to dispose of the old coolant by dumping it into the sanitary sewer via a commode, sink (if the wife's not watching), or an outside cleanout.
If you pull the block plug that's on the side of the engine near the rear on the driver's side you can get another gallon or so out. Seal it with teflon tape when you put it back in.
Old Nov 9, 2007 | 07:48 PM
rustyfuryiii's Avatar
rustyfuryiii
Monsta, dude I was about outa my chair with the drain coolant/oil into hole bit. Then I lost it with the puppies. Funny funny stuff!
Old Nov 9, 2007 | 08:00 PM
Monsta's Avatar
Monsta
Sit. Stay.
It's fun to be the class clown.
Supercab
16
May 2, 2020 05:30 PM
Chuck-B
Aug 4, 2017 09:23 AM
jnye6625
6.7L Power Stroke Diesel
22
Feb 25, 2016 10:19 PM
imsorope
Jan 23, 2016 05:07 PM
stan'37
Aug 27, 2012 06:11 PM
