Shortest Rear end
Old Nov 6, 2007 | 08:22 PM
powerplayer's Avatar
powerplayer
Shortest Rear end
Alright, So what is the Shortest rear end drum to drum that ford makes, or what is the shortest rear end in vehicle history that will be able to handle HP from a 302. No more HP than 320 and no more FT Lbs than 320? If you know, then you can help me. Thanks
Old Nov 6, 2007 | 08:26 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
The 8 inch drop out used in 1974/80 V6 Pinto wagons and 1975/78 Mustang II's with either a V6 or a 302 would get my vote as the shortest. These two cars used rear leaf springs.
The 8" was introduced in 1962, and was the usual rear axle used with: 221/260/289/302/351W's thru 1979, and Ford 6's (mostly 200/250's, and the 2.8L V6) from 1967 through 1980 (some cars with 200 engines used in 1964/66 had 8's also).
8 inchers resemble 9 inchers at first glance. It has a similar removable carrier (pumpkin).
8 inchers were not installed in F Series trucks.
Old Nov 7, 2007 | 10:42 AM
projectnitemare's Avatar
projectnitemare
I wouldn't use the 8inch. Not extremely strong and has little aftermarket. What are you putting it under? The Ford 8.8 is strong than both the 8inch and the Dana 44. The 9inch is a little stronger. If you are going to tub it out you are probably looking at some custom work reguardless; as in narrowing the axle. Out of probably all the axles the Ford 9 inch will be the cheapest to do because of the massive aftermarket for it.
Matt
Old Nov 15, 2007 | 11:07 PM
S1WBuellRider's Avatar
S1WBuellRider
1966-1977 Bronco rear ends are very narrow........ they are 9" rear ends LOTS of aftermarket support and dirt cheap.
I can't remember what year they started using the big bearings on the axle. It might have been 1975. The big bearings are more desirable if you intend to use the stronger 31 or 35 spline axles available through the aftermarket. If you stick to the horsepower and torque levels you said then any one of these axles will work fine.
Like the last post said, avoid the 8" simply because of the lack of aftermarket support.
Good Luck,
Kent
Old Nov 16, 2007 | 12:01 AM
85e150's Avatar
85e150
You can get plenty of 8" stuff here, as well as 9" and custom housings etc.
http://www.currieenterprises.com/ces...ll8inford.aspx
Old Nov 16, 2007 | 12:41 AM
NumberDummy
Kent
1966/72 Bronco with a rear axle load rate of 2750 lb use the 2 13/16" O.D. small wheel bearing.
1968/77 Bronco's with a rear axle load rate of 3300 lb. use the 3 5/32" O.D. large wheel bearing.
Old Nov 16, 2007 | 05:25 PM
rebocardo's Avatar
rebocardo
Maverick rear ends might be the ticket for a narrow rear end. The Mustang II came with a V-8 302/C-4.
porthole
6.7L Power Stroke Diesel
18
Jun 5, 2015 10:02 AM
jamesn7659
Oct 27, 2014 11:08 AM
112233
May 25, 2012 01:36 PM
kevin316
Sep 16, 2011 08:34 PM
ClatonK
Mar 5, 2006 05:31 AM
