Flatbed from newer truck
Old Mar 18, 2008 | 11:35 PM
mgraveman's Avatar
mgraveman
Originally Posted by tshearer
OK, so the flatbed rails outside width is 34" and my truck's frame rails are 38" wide outside. Since I don't have the means to lift the bed onto the truck, I took it to a local welding shop. The are quoting $375 to build a sub-frame setup so the bed will work. I only paid $900 for the truck and $325 for the used bed.
Will the oak 2x4 idea work? My wife is about to kill me over the cost of this bed. What was intended to be a cheap, easy mod is starting to get expensive quick.
Thank you in advance to anyone that can offer a solid solution here...
Tom
I would stay away from a wood support unless it has a frame hitch for the gooseneck and reciever.
I'd consider having them wld some half inch plate in there instead of a subframe. I bet it'll run about a hundred bucks or so.
Where are you located?
