gearing?
I remember a guy telling me that on his 4x4 mud truck he had 4.88s in the rear and 4.10s in the front
That is unless he was running 29" tires in the front and 35" tires in the back....
Which of course would be obnoxious in its own right!
Cheers,
Mike
Cheers,
Mike
I like the way you think
That is one bad little truck! He used it for straight line mud drags, so the bigger wider tires in the back, help with the lanch.
Any way..... If the bronco hasn't been touched, then go to the rear axle, look on the diff cover, and on one of the bolts holding it on, there will be a metal tag. Read it, and see what gear ration it has.(the #s closest to the bolt)
It will show something like 3.55 which is 3.55 gears and open diff or 4L10 which is 4.10 gears and a limited slip. What ever the rear is, the front won't be far off. (ie... 4.09/4.10)
If the rear turns out the be 4.10, and you can put it in 4wd without putting the transfer case in a bind and blowing it up, then the front has 4.09 gears.
Not many people know the codes off the top of their heads, so all he'd need to do is read the tag on the diff(how hard is that, don't be lazy). IF he got it off the door jam, it wouldn't tell him anything, and he'd need to post it up here and wait for a reply from somone that knows. I know, but I don't know when I could of got back to the post.
4.10s were an option so the only way to get it was special order of a new bronco - not many folks have done that. Yes there are some out there, but few and far between. So odds are your bronco came with 3.55s, do a vote the mebers here will be quick to tell you what their broncos came with for gearing.
Axle codes
19 = 3.55s
25 = 4.10s
easy enough.
There are different codes that show if it has a limited slip also, you left that out.
When you said 99% of trucks had 3.55s, that is a wide/wrong statement.
There were 2.75, 3.00, 3.07, 3.08, 3.31, 3.50, 3.54, 3.55, 3.73, 4.09, 4.10, 4.11, 4.30, and 4.56.
Some with open or limited slip, and everone has a different axle code.
19 is only the axle code for a open diff with 3.55s
We are in the bronco thread talking about broncos and most importantly talking about his bronco so my statement holds true in the context of what we are talking about. Axle codes are easy to find, I'll go get them for you.
12 2.73 3800 FORD REG
17 3.25 3300 FORD REG
17 3.31 3800 FORD REG
18 3.08 3800 FORD REG
19 3.55 3800 FORD REG
25 4.10. 5300 FORD REG
29 3.55 5300 FORD REG
35 4.10. 6250 FORD REG
36 3.73 7400 DANA REG
39 3.55 6250 FORD REG
45 4.10. 7400 FORD REG
49 3.55 7400 FORD REG
65 4.10. 8250 FORD REG
69 3.55 8250 FORD REG
72 4.63 11000 DANA REG
73 5.13 11000 DANA REG
H5 4.10. 3800 FORD LIMITED SLIP
H7 3.31 3800 FORD LIMITED SLIP
H8 3.08 3800 FORD LIMITED SLIP
H9 3.55 3800 FORD LIMITED SLIP
B5 4.10. 5300 FORD LIMITED SLIP
B9 3.55 5300 FORD LIMITED SLIP
C5 4.10. 6250 FORD LIMITED SLIP
C9 3.55 6250 FORD LIMITED SLIP
D5 4.10. 7400 FORD LIMITED SLIP
F5 4.10. 8250 FORD LIMITED SLIP
W5 4.10 8250 FORD LIMITED SLIP
He has a Bronco, right, that means he could have a couple different gears in there(3.08, 3.55, and 4.10, w/ or w/out a limited slip).
Just because it's a bronco doesn't mean it has 3.55 gears, a lot might have them, but not 99%
