Sponsored by: Real Truck
low boost, only 5 psi
Old Nov 5, 2007 | 07:37 PM
CircleV's Avatar
CircleV
I recently installed a boost gauge and i'm only getting readings up t0 5 psi but usually lower. I'm wondering if I have a kink in the line but was careful not to during the install and can't see any bad spots. It's on a 2001 7.3 PS w/ a DP 4 position chip. I teed into the map rubber hose and took the red line off the waste gate with no improvement. Any ideas?
Old Nov 5, 2007 | 08:55 PM
Tungsten's Avatar
Tungsten
Does it use a brass compression fitting at the gauge itself with a brass ferrule on the vacuum line itself? If so, maybe you tightened it down too much and crimped the hose partially shut.
Old Nov 6, 2007 | 10:12 AM
FordTruckNoob's Avatar
FordTruckNoob
Once you have determined your boost gauge installation is okay, do the usual checks:
Check for boost leaks
http://www.dieselsite.com/index.asp?PageAction=VIEWPROD&ProdID=607
Check your wastegate actuator
https://www.ford-trucks.com/forums/6...ost-leaks.html
Check your EBP sensor and tube to see if it is plugged
https://www.ford-trucks.com/forums/5...-no-power.html
