Tilt column differences?
Old Nov 5, 2007 | 07:34 AM
psquare7575's Avatar
psquare7575
So I got this tilt column for a good price. (sub $100). I just removed my column because it'd be easier to install my new box, as well as to make way for the new column.
I had thought I just needed to swap the splined end over.
My truck is a 2wd.
This is my end.
http://i9.photobucket.com/albums/a72...k/100_1936.jpg
It appears to be a press fit splined fitting.
Column I got has this
http://i9.photobucket.com/albums/a72...k/100_1937.jpg
Appears to be a splined collar that has a locking bolt?
Questions.
#1. What gives?
#2. Do I care?
#3. Are these ends easily swappable without killing both columns?
If not I'll just wing this column back on eBay and get the proper (2wd I guess?) column.
Old Nov 5, 2007 | 09:19 AM
masterbeavis's Avatar
masterbeavis
I would look into finding a splined rag joint end so you don't have to touch the tilt column to do anything with it. http://www.flaming-river.com/ might be a good place to start.
Old Nov 5, 2007 | 10:23 AM
Mil1ion's Avatar
Mil1ion
What you have is correct.
You obviously haven't read any of my tilt column posts
You just need one of these.
Find one off a E-Series van.
Make sure you get the 11mm or 7/16" 12 point bolt for it.
Note:
When I sell something like this I give the person everything they need right from the start.
IMO, E-Pray is a danger zone
Old Nov 5, 2007 | 10:34 AM
psquare7575
Eh, I do lots on ebay (1098+ feedback as of this writing). I've had 3 negative feedbacks left on me, and all were beyond my control/buyers own fault.
When I was in college, back when scrap metal was worth nothing, I could get a car for free, strip it, and come out +$1000 for a few weekends of work. I've scored many deals on there buying parts as well. (I landed all NOS exterior trim for my Cougar for under $350.. grills/bezels/etc), Even if the splined adapter costs me $25 I still came out ahead. But that's besides the point.
I emailed Mikes Truck Salvage to see what he has. It's dark when I get out of work now, and I just assume have one here for the weekend instead of trying to pull one this weekend.
Go me for doing this entire project outside.
Old Nov 5, 2007 | 10:39 AM
Mil1ion's Avatar
Mil1ion
My reply was based more on the coupler you need
Old Nov 5, 2007 | 11:00 AM
psquare7575
No personal offense was taken, no worries.
As a backup plan.. is there a procedure to remove this from a column without dropping the column, or box?
Old Nov 5, 2007 | 11:21 AM
Mil1ion's Avatar
Mil1ion
The easiest is to drop/move the column.
Everything on the column but the steering rod/tube is interchangeable on a 78-79 E-series.
Great for parts.
