fan clutch?
Old Nov 5, 2007 | 07:30 AM
jw miller's Avatar
jw miller
fan clutch?
It seems my fan is always turning when engine is running. Engine off it seems to take a lot of pressure to move fan by hand. Should it turn easy by hand when not running or not?
Old Nov 5, 2007 | 08:23 AM
Franklin2's Avatar
Franklin2
No, it will be stiff when it's sitting. Usually it will turn and be locked when you first start the truck, and as the fan spins, the fluid moves to the correct places and it unlocks. Even though it is unlocked, it will still turn with the engine. The way you know that it's locked up and not working is it sounds like a 747 under the hood when you are driving down the road. If it's really noisy, then you have a problem.
Old Nov 6, 2007 | 08:34 PM
Bern_F150_4x4's Avatar
Bern_F150_4x4
Franklin's right, a loose fan clutch is a sign of a dead one. They usually loose their oil when they die; look for oil and dirt on the fan blades.
Old Nov 10, 2007 | 04:33 PM
Holmesuser01's Avatar
Holmesuser01
If there are questions about this clutch, and the fan is roaring, just replace the thing. I replaced the original on my '83 351W, and the underhood noise dropped drastically.
Good luck
Old Nov 12, 2007 | 08:31 PM
jw miller's Avatar
jw miller
Well okay seems mine is still good then. Thanks to all for answer.
Old Nov 13, 2007 | 08:12 AM
blue beast's Avatar
blue beast
There are two types of fan hubs, thermo and non thermo!! thermo of course uses heat
to engage. non thermo is always turning at about 60% slip. so if you have that one it
will always be making noise. Feel the center of the front of the hub if it has a little coiled spring it is a thermal unit if no then non thermal. I would change it to a thermal
unit when you get the cash to do it it will save some HP and be quieter, or you could
cut off the cat and run straight pipes.
