302 power steering bracket/tranny question
Old Nov 4, 2007 | 09:43 PM
grebma28's Avatar
grebma28
I have a 72 F250 with 390 that I took the power steering box, pump, and column out of to put into a 68 F100 with 302. Does anyone know if I can use the same power steering bracket off of the 390 to bolt onto the 302 or what I should be looking use?
ALSO: I have a '66 289 Hi Po I want to use in the '68 F100. Does anyone know if this motor will bolt up to a '72 C4? Thanks in advance.
Pete
Old Nov 5, 2007 | 03:35 AM
jowilker's Avatar
jowilker
Pete, I am sure that the ps pump bracket is different between the FE and 302. The pump should fit as long as it is for the same style pump.
There are some bell changes along that time frame with the number of bolts.
John
Old Nov 5, 2007 | 11:25 AM
limegoldf100's Avatar
limegoldf100
A '66 289 should work. The bellhousing change was during the '65 model year.
