Oil Bath cleaner question
Old Nov 4, 2007 | 09:30 PM
Payner44's Avatar
Payner44
Question Oil Bath cleaner question
I just came by an oil bath cleaner for my '64. However, I'm having some trouble with getting it apart to clean and add oil. Now, I have an oil bath on my '58 Chevy pickup which I simply lift the center piece out of the outer shell when needing to clean it or add oil. The cleaner in question is a bit different, the outer shell fits over the center piece and I cannot get the two apart, even though I can spin the inner piece around as it sits inside the outer piece. Is there some sort of Rubic's Cube secret for uncoupling these two compenents or is it simply stuck or am I missing another part altogether?
Old Nov 5, 2007 | 07:45 PM
64fordf100292's Avatar
64fordf100292
it should just pull apart. thats how mine works anyways. while we are on the subject of the oil bath air cleaner, and i ont mean to take over your thread,but how do you clean the bloody things???? just pull it apart, spray the heck out of it with brake cleaner and then just put like a pint of oil in the bottom part of the air cleaner and its cleaned????
Old Nov 6, 2007 | 05:10 AM
jowilker's Avatar
jowilker
Old timers used gasoline. That was before these fancy and cheep carb. & brake sprays were available.
John
Old Nov 6, 2007 | 10:22 AM
daveengelson's Avatar
daveengelson
Just for info purposes, there is an article in the 'article/spec' forum with pics on how to convert from oil to filter and maintain original appearance.
dave
Old Nov 6, 2007 | 10:47 AM
Payner44's Avatar
Payner44
It looks simple enough...however, the one issue I see is finding a paper filter to fit correctly...and if you can do that then I'm sure a cheap chrome top in the right size could be had, instead of making one as the instructions point out.
Old Nov 6, 2007 | 11:21 AM
daveengelson
Heck, put a fomoco decal on the bow tie air cleaner from your 58 and don't tell anyone. As John mentioned, probably just as easy to flush w/ gasoline or substitute and fill w/ oil. If should decide to modify and interested in maintaining original appearance suggest check salvage yard, or search ebay under 'oil bath air cleaners' and see if able to find one where lid is not attached. I will deny if ever asked, but if i could find a lid that worked not sure I would be concerned whether manufactured by fomoco, replacing entire air cleaner would be another issue. Recently sold 49 bow tie and there are couple of style air cleaners where the lid is not attached. Anyhow, food for thought.
dave
Old Nov 6, 2007 | 02:15 PM
Payner44's Avatar
Payner44
dave
When referencing the chrome top, I meant using it instead of a plastic lid from a container to accomplish a seal over the paper filter...sorry for the confusion. No way I would go through all this modification only to screw a chrome top on the entire cleaner...
Old Nov 6, 2007 | 03:04 PM
Redmanbob's Avatar
Redmanbob
I too like the idea of converting the thing to paper element with stock housing. However until I find one to tear up the original will remain as is. As for cleaning I used B-12 Chemtool in mine, just poored about a qt in it and sloshed every few minutes. Did this with fresh solvent until it was pretty clean when remving. Turned it over in the sun for a few hours to dry. Flipped it filled it to the line/ring with 5/15W and put it back on.
Bob
F250Rob
44
Oct 11, 2017 08:49 PM
DGMFORD
Aug 22, 2014 04:55 PM
Faber
Nov 15, 2013 05:30 AM
OldHarley
Jan 13, 2010 04:51 PM
harrytoes
Jun 3, 2007 06:20 PM
