Ranger axles
Old Nov 4, 2007 | 09:15 PM
danield's Avatar
danield
Ranger axles
I have seen on the 8.8 rear they offer 2 different axles one is like 19 spline and I think the other is 22 spline. Would anyone know wich one a 95' ranger 4x4 ,4.o liter would have?
Old Nov 4, 2007 | 10:30 PM
BuffmanLT1's Avatar
BuffmanLT1
IIRC they should all be 28 spline axles. Length might be different though.
Old Nov 5, 2007 | 12:03 AM
danield's Avatar
danield
Rear axle
Maybe I should have stated rear axle splines. 28 spline is the front axle at the hubs, atleast I think so. I need to know the rear spline #'s
Old Nov 5, 2007 | 11:53 AM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
You really should check again. Ranger's had 28 splines in the 8.8, Explorer's had 31 splines in the 8.8.
Old Nov 5, 2007 | 12:23 PM
wendell borror's Avatar
wendell borror
The FX4 level II also the 31 spline axles, the rest of the rangers were 28 as been stated.
Old Nov 5, 2007 | 03:58 PM
projectnitemare's Avatar
projectnitemare
Unless someone swapped it. Measure the axle tube. If it's around 3.5inches or so you have a 31 spline. Most likely you will have a 28 spline which is around 2.75 at the tube.
Matt
