Ball joints
Old Aug 10, 2008 | 09:41 AM
scatgo's Avatar
scatgo
Don't forget to get a alignment after replacing the ball joints. You are sure to knock the alignment out of wack when you replace the ball joints. If the alignment is way out the handling of you truck could be to the point of dangerous. If its not that bad your tires are still sure to get busted up so play it safe and get it done.
Old Aug 12, 2008 | 08:09 PM
arkredneck's Avatar
arkredneck
i finally got the ball joints in broke down and bought a 20 ton press from harbor frieght made the job fairly easy just had to rig up the knuckle in the press the only thing i noticed about the truck was that the spindle or hub whatever you call it the shaft the bearings and rotor slide had pits in it and looked at little worn i guess i'm gonna replace it and the bearings when i have more time
briangelc
Jan 4, 2020 08:37 AM
mgmoore7
Sep 18, 2016 09:00 PM
vavtx
Sep 11, 2016 11:45 AM
jnoble87
Apr 18, 2016 05:23 PM
boosteddsm
Jun 15, 2011 09:44 PM
