Checking Fusible Links
Old Nov 4, 2007 | 06:13 PM
86f250460's Avatar
86f250460
So I switched the battery terminals on my truck.. it smoked...took the wires off the starter solenoid and wanted to check my fusible link...how do i do that?
Old Nov 4, 2007 | 07:59 PM
Piffery1's Avatar
Piffery1
If you have an Ohmmeter measure the resistance, it should be nearly zero Ohms.
Old Nov 6, 2007 | 07:58 PM
ford_boy_1996's Avatar
ford_boy_1996
I just feel the wire and bend it if it stays bent than its still good you can tell or use a ohmmeter
Old Nov 6, 2007 | 08:32 PM
PsychoworkS's Avatar
PsychoworkS
What????????
If you bend it and if it stays bent than it's still good?????
That's the first time I've ever heard that one.......
Old Nov 6, 2007 | 09:06 PM
ford_boy_1996
Originally Posted by PsychoworkS
What????????
Yeah because if the link is burned there is no wire in it so it is just rubber. ITS JUST MY WAY OF CHECKING THEM NO NEED TO MAKE FUN OF ME LOL
Old Nov 20, 2007 | 10:00 AM
86f250460's Avatar
86f250460
Okay...still haven't fixed it yet..need help again...so give me a breakdown step by step about it
Old Nov 20, 2007 | 01:19 PM
Mil1ion's Avatar
Mil1ion
Just unwrap the tape on the harness from the relay ..leading toward the fuse box.
It will be highly evident that if it has melted.
Old Nov 20, 2007 | 11:51 PM
86f250460's Avatar
86f250460
Thanks. I'll try it out..Just the beast has to move or she's getting towed...do you think it fried the battery too?
Old Oct 21, 2024 | 03:52 PM
69 Ford's Avatar
69 Ford
Trailering
I am trying to locate the fusible links on my 1969 F350 ?
Old Oct 21, 2024 | 04:55 PM
Max Capacity's Avatar
Max Capacity
https://www.google.com/search?q=loca...hrome&ie=UTF-8
Does that help ?
Old Oct 23, 2024 | 08:03 AM
Bronco638's Avatar
Bronco638
A wiring diagram should indicate the gauge of the link. You can find replacement links at any good auto parts store. They may not look the same but they will work the same.
Old Oct 25, 2024 | 09:13 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Not that someone here may not know but asking in the 1967-72 F-100 and larger F-Series forum instead of the 1980-86 forum might get you better results.
Old Oct 25, 2024 | 11:42 AM
69 Ford's Avatar
69 Ford
Trailering
ok thanks I'll try to find it
emgee
Apr 16, 2016 04:05 PM
wmangus
Dec 28, 2014 07:01 PM
Island Time
Electrical Systems/Wiring
Jul 6, 2014 07:26 PM
Onus
Oct 1, 2011 09:36 AM
papadelogan
Jan 3, 2008 04:52 PM
