300 needs more stroke
Old Aug 30, 2002 | 03:09 PM
tmcgin's Avatar
tmcgin
Been thinking about rebuilding a 300 in an 82f150 that i have just sitting in the back yard. I've decided to build a high performance motor.
Ideas:
1. Stroke the motor more, say at least 4.5".
2. efi exhaust headers
3. offy intake, 4 barrel carb
4. head work
I'm thinking this extra stroke will give me the power i want.
My guess 300-350 hp, 400 lb-ft torque.
Comments?, ideas?
Old Aug 30, 2002 | 03:13 PM
chuckman's Avatar
chuckman
The extra stroke really won't do too much for a motor that was a stroker in the first place. Sure it will give more torque, but probably so low down that you'll never find a gear ratio to keep you in that rpm range. Plus, it wont rev high enough to get a good hp peak, so you might get up to speed fast, but you wont be going that fast. I'd focus more on porting the head, some flat top pistons, and some other tricks to raise compression.
Old Aug 30, 2002 | 06:57 PM
GammaDriver's Avatar
GammaDriver
They may be strokers, but I'd say there's room for more torque from idle to 1500 RPM anyway. I have a 5-speed and wouldn't mind seeing more "oompf" around there.
Not that I'm going to do it, but where would one get the crankshaft and connecting rods to do it?
Old Aug 30, 2002 | 09:25 PM
StrangeRanger's Avatar
StrangeRanger
Clifford makes a stroker kit for the 300, it increases the stroke to 4.375. It costs an arm, a leg and your first born and their service is typically so bad, you may wait a very long time to get it. But why bother? All you really get is reduced volumetric efficiency and a lower rev limit on an engine that is somewhat low revving in stock form. The 300 already has all the stroke than the stock head can possibly support. Spend your money on the head, you can pick up over a thousand usable RPMs
Old Aug 30, 2002 | 11:02 PM
MustangGT221's Avatar
MustangGT221
I second strangeranger.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Heavyduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Weighs around 7,000lbs w. 65mph top speed, who wants to race me!
Old Aug 31, 2002 | 09:18 AM
Vampiro's Avatar
Vampiro
why not just bore it out to around 309, headers, glasspack exhaust, 4 bbl carb, ry to raise compression if possible, hi-pro cam, better erar end gearing, to around maynbe 3.8ish?
you can have all the horse power in the world, but can your rear end take it?
Old Aug 31, 2002 | 11:14 AM
straight6 man's Avatar
straight6 man
