It would be in your best interest to have a custom CV driveshaft built for your truck. The pinion angles will be out of wack and the one piece drive shafts cannot compensate nor adjust to extreme angles with only one axial U-joint. A set of differential shims will help as well.
Cost me $300 for my new shaft using a spicer 3/4 ton CV knuckle with two more HD u-joints than the stock shaft. My new driveshaft was also an inch and a half longer than the stock unit.
If the driveshaft is too short, you will increase the wear on the output shaft bushing on the transfer case. Your driveshaft will be barely adequate with 6" lift. It will slip out 2-3" further on the slip yoke.
Speak to a driveline shop... they may have used parts for your applications. If you plan on modifying your truck, expect to have to mess with these driveline issues.
Or have fun chasing the vibration ghosts after the lift!
My driveshaft pulled out about 3/4". Will trig it out exactly at work Monday. Have had 4 F-150 with 6 inch lifts with stock driveshafts front and rear with no problems. 2 S/B 1 L/B 1 S/B Ext Cab. Ive had the best luck with skyjacker kits.
Waynaferd... be prepared for vibrations. Whatever route you go.
tell me about it i got a s/b with almost 8 on it and man are the vibrations getting old anyone know if they are any good sites to a double cv shaft made?
Look in your phonebook for a driveline service place. They can weld you up a custom to your truck shaft that will be well worth it!
Give them a call for measurements. They will treat you right.
Some degree shims for your differential will help alot in conjunction with the cv shaft. Point that pinion right at the tcase with a good spicer CV joint in there and your vibrations will be a long lost memory. Driveshaft binding and poor pinion angle are probably both contributing to your vibration.
also... if you've been driving with these vibrations for some time... you might want to pick up a rear seal and bushing for the bw1356. The vibrations will wear that bushing out and cause further rubbing down the road. Well worth the $25. With the shaft out... its a ten minute job. I believe you can get the set at broncograveyard.com.
96, that rear shaft has some serious angle. No wonder it vibrates. Nice looking truck. What is the angle,like 40 degrees? I here you can rotate your t-case, but dont know how that works. Good luck.
Mike, just curious here but... How would a two piece driveshaft make lifting the truck better? So you can divide the pinion angle into two and put a bit of an angle at the center u-joint? Because I was under the impression that even a two piece driveshaft should be as straight as possible... I've got a two piece and it made an AWFUL vibration from a stop after being lifted until I shimmed it down...
