dist. questions
Old Nov 4, 2007 | 11:28 AM
claude mccumber jr's Avatar
claude mccumber jr
dist. questions
After setting the timming and turning off truck. I tighten the hold down nut and mysteriously the timming and idle changes{obviously from the timming changing}. So I tried tightening it with truck idling, same results. I've tightend it just till it starts to change then back it off just a little and leave it.{Not very tight at all}
What causes this?[single point system]
Also---
Inside vaccum advance port there is a allen screw. What purpose dose it have and if some sort of adjusting feature, how can I utilize it?
[ 74 f-250 390 c6]
Post script;
Still looking for vaccum diagrams.
Old Nov 4, 2007 | 06:18 PM
smoke n tires's Avatar
smoke n tires
you may have loose springs in the mechanical advance inside the dist. also make sure the dist isnt binding up. if it does the cam will turn the whole dist instead of spinning it. not very common but ive seen it once or twice. that will change the timing. as for the vac adv. i hook mine up to ported vac. thats so theres no vacuum until the motor revs and then it slowly advances the timing. the allen screw is an adjustment but i cant remember which way to turn it to do what.
Old Nov 4, 2007 | 07:00 PM
claude mccumber jr
Thanks/I was thinking down the same lines.Wondering if the time for replacing the dist. is at hand.
Thanks again
Old Nov 4, 2007 | 07:05 PM
2classics's Avatar
2classics
The allen wrench changes how fast the vacuum adv. comes in. Clockwise is faster i think.
Old Nov 4, 2007 | 09:16 PM
Mil1ion's Avatar
Mil1ion
Change the Original post to the default font so I can read it and maybe I can help ?
Old Nov 4, 2007 | 10:50 PM
masterbeavis's Avatar
masterbeavis
I've never seen timing change by the pressure of the clamp, normally its because I am ham fisted and bump the distributor with the wrench. What kind of wrench are you using to tighten the nut with. How far does the timing change when you tighten the clamp down all the way? If I were doing it, I would set the timing that much further off, so when I tightened the clamp, it would move to exactly where I wanted it.
Old Nov 5, 2007 | 04:28 PM
claude mccumber jr
{Sorry about the font confusion.Here it is in a regular font style.}
[ORIGINAL MESSAGE]
Also---
Inside the vaccum advance port there is a allen screw. What purpose dose it have and if some sort of adjusting feature, how can I utilize it?
[ 74 f-250 390 c6]
Post script;
REPLY TO POSTS
The timming retards aprox. 8 deg. I didn't think about advancing it that much further. I'm using a 1/2" comb. wrench.I was real carefull not to move the dist. after this happend 4 times/ could a messed up dist. gear cause this??
So turning the allen clockwise would cause it to be more "sensitive" kinda?
Thanks for all the help guys.
Last edited by claude mccumber jr; Nov 5, 2007 at 04:34 PM. Reason: Change lay out
Old Nov 5, 2007 | 07:02 PM
Mil1ion's Avatar
Mil1ion
Okay thanks.
In regards to "TIMING".
Instead of really loosening the distributor hold down bolt just loosen it enough to move the dist then adjust shut engine off and try tightening.
Or.....Also they make a "dog leg" type wrench for dist bolts so you can tighen them with the engine running without worrying about catching the fan.
I found a 2 wrench set for $8.00
In regards to Vacuum diagrams I probably have something here that will work.
This for a M/T though.
I'll check my books for one for an A/T.
Old Nov 5, 2007 | 08:53 PM
claude mccumber jr
Thanks for the info and diagram. I'm thinking of getting a new dist. and installing a points converter, any thoughts?
Old Nov 5, 2007 | 10:52 PM
four4x4fords's Avatar
four4x4fords
I don't believe 'new' Ford distributors are available for our trucks.
I gave up on re-built distributors and got a Mallory Uni-Lite for mine. No problems with it in over 7 years use. My nephew runs an Accel dist in his 78 Bronco and has had similar results with it.
Old Nov 5, 2007 | 11:22 PM
ErrorS's Avatar
ErrorS
I posted almost the exact same thing in the engine forum.. they all said it was probably the mechanical advance messed up.
Was goign to fix it, have a spare dizzy with a mechanical advance that I *know* works, but stripped the damn phillips holding the covers in. Trying an acid wash to get them out.. but I think I'll just end up replacing this distributor as well (sick of buying distributors for these trucks..)
Old Nov 5, 2007 | 11:33 PM
Mil1ion's Avatar
Mil1ion
Claude , is there a white sticker on the valve covers to get numbers off of ?
Otherwise, I need to know the rear axle ratio
Old Nov 6, 2007 | 07:54 PM
FESTER1st's Avatar
FESTER1st
I dumped the points dist for a mallory mag breakerless dist having some trouble getting the advance curve right though. I chose this for diversity of coils and addons. Malloryracing.com is a good place to investigate, also in instructions\ page 2\ tips for increased performance and gas milage, gives a good explanation of what the allen screw does. I'm no computer wiz so I dont know how to post the link.
Old Nov 6, 2007 | 11:14 PM
four4x4fords
Another good Mallory resourse http://www.centuryperformance.com/ma...allorytech.asp
Old Nov 9, 2007 | 11:34 AM
claude mccumber jr
Rear axle is a dana 60 4:10
