Sponsored by: Real Truck
Front End "Creeking" ??
Old Nov 4, 2007 | 07:41 AM
jstutz101's Avatar
jstutz101
I have a '99 SD that I recentley noticed has a strange "creeking" noise. It only does it when turning right while braking. Any ideas??
Thanks,
Jeff
Old Nov 4, 2007 | 08:02 AM
del_allen1957's Avatar
del_allen1957
I had the same thing on my 04 - had to replace a ball joint
Old Nov 4, 2007 | 05:17 PM
boxcar1974's Avatar
boxcar1974
If it creaks as you brake, apply different levels of brake to see if you get the front end to "bounce". If it creaks accordingly than you most likey need to lube you leaf spring bushings. My 03' does it alot. I spray PB Blaster on them and they stay quiet for a month or so.
Old Nov 4, 2007 | 05:35 PM
Packrat Super duty's Avatar
Packrat Super duty
I just replaced all 4 ball joints, and all the "creeking" went away with them.
I thought it was the spring bushings too, Creek was only happening once and a while. But since ball joint replacement. All is quiet up front for now......oh! umm..... forgot about the "clunk"......
That's the stablizer arm from the frame to the bar.... passenger side.
Old Nov 4, 2007 | 05:36 PM
Packrat Super duty
boxcar1974.... What is PB blaster.... never heard of that.
Old Nov 4, 2007 | 10:22 PM
swann79's Avatar
swann79
PB Blaster is a penetrating oil, kinda like WD-40, only lots of folks like it much better. Not sure where you can buy it though...
Old Nov 4, 2007 | 11:02 PM
Gevans17's Avatar
Gevans17
Another creaking Ford front end
mine stopped after replacing upper and lower ball joints
Old Nov 5, 2007 | 07:26 AM
GregN's Avatar
GregN
I have new ball joints and that didn't help. I replaced the Swaybar End Links and that took most of the creaking away.
Old Nov 5, 2007 | 10:11 AM
mackstruck's Avatar
mackstruck
Mine does it on the drive side, only when it is cold. After about a half hour of driving; I guess what ever is causing the noise, warms up and stops creeking. I have greased all of the zurk fittings and sprayed WD40 on every thing, but it has not stopped.
I was thinking that maybe the shock is going bad.
Old Nov 5, 2007 | 10:13 AM
GregN's Avatar
GregN
Yeah, that is what I originally thought, but I bought all new Bilstein shocks and it didn't help a thing. If you have the factory original shocks upgrade them anyways. You will get a much better ride. I doubt you will be dissappointed.
Old Nov 5, 2007 | 04:56 PM
jstutz101's Avatar
jstutz101
Funny you say that because I was trying to recreate the trouble yesterday in a empty parking lot and there was no noise at all. When it is acting up it is pretty loud.
Thanks for the replies!!
Jeff
Old Nov 5, 2007 | 05:24 PM
CobraGT40's Avatar
CobraGT40
Mine had the same thing at 36,000 miles...accompanied by a clunking at times...had upper and lower ball joints replaced with lifetime-warranty ball joints from Napa at a local shop for about $500 clams including labour... Been great ever since and am about to turn 95,000 miles...
Scott
Thanks,
Jeff
Old Dec 7, 2007 | 03:13 PM
5.4L to Freedom's Avatar
5.4L to Freedom
I know this is old, but Advance Auto stocks PB blaster, once you go to PB you'll never go back to WD
