brown
Old Nov 3, 2007 | 09:16 PM
menzfamfour's Avatar
menzfamfour
brown
i checked the front differental and the gear oil was brown is that really bad thanks guys
Old Nov 3, 2007 | 09:35 PM
Mil1ion's Avatar
Mil1ion
I would say that is a good thing.
Old Nov 3, 2007 | 09:38 PM
menzfamfour
why would you say that i was told it should be greenish
Old Nov 3, 2007 | 09:41 PM
menzfamfour
so is that ok i really would like to know
Old Nov 4, 2007 | 07:32 AM
PsychoworkS's Avatar
PsychoworkS
Brown is your FRIEND......... What can brown do for you?
Lube your gears it can.
Old Nov 4, 2007 | 08:50 AM
lostin90s's Avatar
lostin90s
yep unless it was flushed out and the fake lube out in . The brown is what you r looking for . When it get really dark it needs changed . Good luck
Old Nov 4, 2007 | 09:50 AM
blue beast's Avatar
blue beast
It should be transparent brown, No milky or chocolately milky look!! Where is you vent
line and is it cracked at the axle or plugged? Run a new extended line for the front and
rear differential.
