touch up paint
Old Nov 3, 2007 | 02:42 PM
deficientblair's Avatar
deficientblair
touch up paint
Where's the best place to buy touch up paint? ive got a couple of door dings and other unwanted scratches that id like to get rid of
Old Nov 3, 2007 | 03:11 PM
firemedic716's Avatar
firemedic716
Touch Up paint.
Well, it depends on what you are trying to do with it. If you're looking to spray the paint like a pro I recommend using DuPont's Chroma system. I've used it on quite a few cars and my own screw and it flows very well and comes out looking original. However if you're just trying to touch up some small dings or scratches with a small brush I always use... Fingernail polish. ( I know). But many people don't realize that the touch up paint you buy at the local auto parts store is very quick drying and also quite thick which means that when you apply it it will leave a clumpy spot on your finish. Using a close (doesn't have to be exact) color to your factory paint finger nail polish actually flows out smoother and isn't as noticeable when done. Always clean the area prior to touch ups. ( I use a Q tip and alcohol so I know that the wax is removed). Good Luck!
Old Nov 3, 2007 | 08:28 PM
FTE Trigger's Avatar
FTE Trigger
Duplicolor had that two sided marker/bottle that had the ball-point (pen type) dispense along with the small brush.
