Air Compressor Question Help
Old Nov 3, 2007 | 04:11 AM
Concept25's Avatar
Concept25
I have a 2000 Explorer,air works fine but I'm getting a clacking noise from the front of the compressor. I noticed the front disc plate near the belt is loose and is making the noise, is this a bad thing????? Do I need a new unit????
Old Nov 3, 2007 | 06:55 AM
marragtop's Avatar
marragtop
Does it make the noise only when the compressor engages?
Old Nov 3, 2007 | 09:58 AM
Concept25's Avatar
Concept25
It makes noise all the time even when the air is off, thanks When the motor is off I can grab the front of the compressor seems like the clutch plate is loose?????
Old Nov 5, 2007 | 07:56 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Have you checked the Idler pulley??
